11-17-2013, 10:44 PM | #1 |
Newbie Join Date: Mar 2013 Location: Sandy
| Novak Goat 3s gearing
Other than the issues I am having with the speed control shutting down. What is a good pinion/spur combo in an SCX10. Want good speed but enough torque to get up and out of tough situations. Sent from my iPad using Tapatalk |
11-19-2013, 02:35 AM | #2 |
Looking for a pinion spur combo on the Goat 3s
11-20-2013, 10:57 AM | #3 |
Newbie Join Date: Mar 2011 Location: wisconsin rapids
| Re: Novak Goat 3s gearing
I run a 17.5 with an 18 tooth pinion and the stock spur and never had an issue...actualy the only issue I ever had was twisting drive shafts like pretzels
11-20-2013, 09:25 PM | #4 |
Rock Stacker Join Date: Aug 2013 Location: Salina
I am running the Novak 18.5 sensored crawler motor and Goat 3s esc in my mattZilla jeep Cherokee. Its gearing is at 16tooth pinion, and a 87tooth spur. Its a great ratio for it, and I dont have any issues with heat or lack of power, or torque. Ive also never had my esc shut down yet due to any reasons. So i can only think its programming isnt exactly right on. Maybe in the wrong profile?? It has three profiles to set it to. One is a worm gear profile, and one is a sensored setup, and the third one I cant honestly remember. But I really do like my setup, and the way it handles.
11-20-2013, 11:59 PM | #5 | |
| Re: Novak Goat 3s gearing Quote:
In general, a 5:1 pinion/spur ratio is a good starting point. | |
11-21-2013, 08:40 AM | #7 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
Your gear set up, will be dependent on your tire size and over all weight more than any thing. I run a tall 1.9 and have a heavy truck, I run a 12/87 combo. That works for me, what works for you will be different. I would start at a 15 -18/87 combo and go up or down from there. Novak has great customer service, and a trade in program, send that esc to them and let them help you figure it out. |
Novak Goat 3s gearing - Similar Threads | ||||
Novak Goat Vs Novak Goat Ballistic?? | k_r_a_c_k_e_r | Electronics | 3 | 02-19-2010 07:53 PM |
Gearing? With novak goat 3s and 18.5 | C_Money | Axial SCX-10 | 1 | 12-28-2009 05:03 PM |
Novak GOAT ESC only works with Novak BL-Motors? True? | spiderschwein | Electronics | 6 | 09-01-2008 04:11 PM |
Stock gearing OK with Novak Goat combo? | BeeRC | Axial AX-10 Scorpion | 10 | 05-27-2008 03:04 PM |
