11-19-2013, 04:05 PM | #1 |
Pebble Pounder Join Date: May 2013 Location: Nobleboro
| esc for 12 turn
Looking for some advice on an esc. Requirements: handle 20 turn motor ,up to 8 cells (nimh), with drag break. This is for my ramcharger scaler build.
11-19-2013, 04:08 PM | #2 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
Cheap, axial AE-2 or sodewinder. Higher side, mamba max pro so if in the future if you want to go brushless you can, or the holmes brxl
11-19-2013, 06:15 PM | #3 |
| Re: esc for 12 turn
I was under the impression that the ae-2 was only good for 6 cells. My sons ridgecrest burns through a 6 cell 5000 like nothing. mind you all I have is nimh batteries. will go lipo some day just not now. |
11-19-2013, 06:22 PM | #4 |
Pebble Pounder Join Date: Nov 2012 Location: springfield
| Re: esc for 12 turn
6 cell 7.2v is the same as a 2s lipo since it runs at 7.2v also. escs are dumb they can't tell the difference between the 2 the draw back is you need to run either low voltage alarm or cuttoff when using lipo. The ae-2 runs 2s and 6 cell and if i remember right has the built in lipo cutoff turned on from the factory so its fine. It can also run 3s lipo but they recommend installing a bec for 3s.
11-19-2013, 06:22 PM | #5 |
Newbie Join Date: Sep 2013 Location: Monroe County
| Re: esc for 12 turn
IM running a sv3 with my 35 turn and its brushed/brushless 3s lipo compatible too and waterproof for those mud bogs |
11-19-2013, 07:48 PM | #6 |
Run a cc bec, and I've run mine on 4s. The AE-2 has been bullet proof for me.
esc for 12 turn - Similar Threads | ||||
Question about Turn rating on an ESC. | NewB_SCX10 | Electronics | 6 | 01-02-2011 07:52 AM |
ESC Turn limits | Oze30 | Electronics | 10 | 02-09-2008 12:42 PM |
55 turn and stock ESC...??? | JLOC | HPI Wheely King | 10 | 04-23-2007 12:56 AM |
esc and motor turn limit. | 3L3ectricracer135 | Electronics | 3 | 12-08-2004 08:57 AM |
