11-20-2013, 04:48 PM | #1 |
Pebble Pounder Join Date: Mar 2007 Location: cleveland
| removing on off switch
i have a mamba max and im curious as to removing the on off switch..what is the benefit and do the two wires have to be connected or can i just remove them all together at the board? reason im asking is the on off wire got damaged.
11-20-2013, 04:55 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: removing on off switch
Benefit is no switch failure to worry about. Yes the two wires have to be connected. If you remove them from the board the two contact points will need to be connected to make the circuit. |
11-20-2013, 04:58 PM | #3 | |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| Re: removing on off switch Quote:
Just remember to disconnect the battery as you always should when not using the rig. | |
11-20-2013, 06:51 PM | #4 |
Thats the other plus, keep the inactivity beep enabled and it'll always remind to disconnect battery. Agreed with above.. cheap switches on esc's become a headache sooner or later. |
removing on off switch - Similar Threads | ||||
Light Switch for Your Scaler - Firmtronics RC Switch Review | roktoy | Electronics | 29 | 09-15-2015 02:37 PM |
Wiring a switch to switch polarity | builder | Electronics | 5 | 05-20-2013 07:55 PM |
Removing On/Off Switch from ESC | armycrawler101st | Electronics | 9 | 01-27-2011 03:12 AM |
Removing the On/Off switch from an ESC | Whirlybird | Electronics | 18 | 08-08-2008 09:04 PM |
removing esc switch | TIMZKRAWLER | Electronics | 7 | 11-28-2007 07:04 AM |
