11-24-2013, 12:22 PM | #1 |
Newbie Join Date: Nov 2013 Location: Tampa, FL
| Help with Sidewinder 3 Flashing Yellow
I'm just about complete with the Wraith kit, but my Sidewinder 3 just beeps with the flashing yellow light. I initially calibrated the ESC last night, and everything worked, so I went to sleep. This morning, no joy. The receiver seems to be working because the steering servo responds. My setup: ESC Sidewinder 3 (changed the setting to brushed motor with the CC Field Link Card) BEC Castle Creations Motor Axial 20T Btry 3S 2200mah Radio/TX Traxxas 27mhz 2 channel TQ3 |
11-24-2013, 12:27 PM | #2 |
Rock Crawler Join Date: May 2012 Location: Columbus
| Re: Help with Sidewinder 3 Flashing Yellow
are u using the right wire configuration
11-24-2013, 12:33 PM | #3 |
Do you mean from the ESC to the motor? If so, I'm using two wires from the ESC to the motor.
11-24-2013, 12:39 PM | #4 |
I just plugged the ESC into the 1st channel and got it to work perfectly, even calibrated it with the steering wheel acting as a throttle. When I plugged it back into the 2nd channel, the yellow just flashes. Is this a bad receiver?
Last edited by Asjackman; 11-24-2013 at 12:40 PM. Reason: To get response notification. |
11-24-2013, 02:32 PM | #5 |
Looking at this..... Castle Creations | FAQ: 1/10th Scale Products , a lot depends on what you're doing.
11-24-2013, 03:16 PM | #6 |
Quarry Creeper Join Date: Dec 2011 Location: Doylestown
Try the RX slot right after the one u r plugging into. Same happened to me and most traxxas RX have 2 channel 1 then a channel 2
11-24-2013, 06:08 PM | #7 |
I plugged in the ESC into Channel 1 and I can fwd/rev/brk with the ESC/motor. Seems like channel 2 is inoperable. The receiver has 3 channels, is there any way I could mod the radio to send the throttle or steering signal through channel 3? The TQ3 radio is a 3 channel (2 position) radio. I'll try other combinations of channels on the RX |
11-24-2013, 10:11 PM | #8 |
Now channel 1 is not working. I am quitting with the Traxxas RX, could it be possible that the ESC/LIPO has fried the RX? Anyway, ordered a Fly Sky GT3C. Was hesitant about it, but needed something at a low cost. Starting this hobby got expensive... quickly.
11-25-2013, 08:10 AM | #9 | |
| Re: Help with Sidewinder 3 Flashing Yellow Quote:
The internal BEC outputs voltage through the ESC to RX wires. | |
11-30-2013, 07:25 AM | #12 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
What voltage was the became set on? If it was more than 6 volts it may have fried the receiver.
11-30-2013, 07:30 AM | #13 |
I just checked, it was at 5.1, I just increased it to 6.0 using the GR3E rx.
Help with Sidewinder 3 Flashing Yellow - Similar Threads | ||||
leds flashing | jeepscx10 | Electronics | 3 | 03-10-2013 06:11 PM |
PLEASE HELP Esc flashing | Lilred | Electronics | 2 | 06-13-2010 08:25 PM |
Rooster and RX flashing... | Greatscott | Electronics | 1 | 12-02-2009 11:34 PM |
Flashing LED's | BlueMonster | Electronics | 0 | 02-11-2008 11:02 PM |
Looking for red flashing L.E.D.s | TREVORS_DAD | General Crawlers | 4 | 08-06-2006 02:05 PM |
