11-26-2013, 08:07 AM | #1 |
Rock Crawler Join Date: May 2012 Location: Columbus
| power block/strip
is there a power block i can plug my charger into so I can charge more at once??
11-26-2013, 08:37 AM | #2 |
| Re: power block/strip
Not if you want to balance charge the batteries. This is where the 4 port chargers come in like the X4 AC Plus 4 Port ACDC Multi-Charger. It can charge 4 of the same at once, or 4 completely different batteries all at once. It has the power supply built in so it can run off of a wall outlet, or car battery using clamps or the cigarette lighter. It's what I use and I've sold probably 10 of them after people have either seen mine in use or used mine at a comp. X4 AC Plus 4 Port ACDC Multi-Charger | HITEC RCD USA |
11-26-2013, 08:43 AM | #3 | |
| Re: power block/strip Quote:
A) Parallel Charging Board, plugs into your single charger and charges multiple batteries at once. I don't know enough about parallel charging to be able to recommend this route, do some reading up and research. B) Power Supply Distributor, allows you to plug multiple DC chargers into one power supply. | |
11-26-2013, 09:53 AM | #4 |
thanks
11-26-2013, 11:03 AM | #5 | |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
11-26-2013, 12:37 PM | #6 |
whats a para board
11-26-2013, 01:55 PM | #7 |
| power block/strip Last edited by rcmedic; 11-26-2013 at 06:28 PM. |
11-26-2013, 01:56 PM | #8 |
| Re: power block/strip |
power block/strip - Similar Threads | ||||
Strip a NB JK | robvbro81 | Paint and Body | 0 | 11-25-2009 07:30 AM |
how do i strip anodizing?? | 1TONCHEVY | Tools, and Procedures | 24 | 02-25-2009 06:44 PM |
Strip Clubs in Vegas | Cloak | Chit Chat | 22 | 06-06-2008 10:25 PM |
The Power Block On Spike Tv ???? | CRUZ CONTROL | Chit Chat | 26 | 10-22-2007 11:51 AM |
should i strip or sand | gigercrawler | Paint and Body | 8 | 10-20-2007 05:45 AM |
