11-27-2013, 04:56 PM | #1 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| 27 turn TorqueMaster Expert 540
I've had this in my drawer for a little bit and about a month ago dropped in my scaler. I probably have ran 6 hours max on it to get my truck tuned. It has never got hot or been in mud or water. I have never gone thru brushes this fast? BXRL is programed correctly as is the gear ratio. Any ideas?
11-27-2013, 05:15 PM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: 27 turn TorqueMaster Expert 540
a buddy & I have the same one as you, and they also eat brushes. but we get more than 6 hrs on it , not really sure why they go so fast, now on my 35t it seems they last forever. |
11-27-2013, 05:20 PM | #3 |
I was at the Holmes page looking for new brushes. I know it came with copper brushes but as a upgrade they have silver. I would think they would last longer? Worth it? There only 2 bucks more.
11-27-2013, 05:29 PM | #4 |
Just saying "silver", I will say they last longer. Those brushes are REALLY wiped!! |
11-27-2013, 05:30 PM | #5 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
If youre using it in a lot of mud or sand they will go pretty fast...Youre timing can determine wear times as well...if your timing is set at zero...try -5 degrees and that should help a little. If you do a lot of fast running; that will wear them down faster also.. You can get a harder brush but that will wear the comm out faster If you run in mud/water and sand stick with a soft brush and time it for best wear cheaper to replace the brushes than a armature even though they aren't really expensive for that line of motors Last edited by 6sharky9; 11-27-2013 at 05:37 PM. |
11-27-2013, 05:41 PM | #6 |
Pebble Pounder Join Date: Feb 2013 Location: Fresno
The silver will last longer but your copper brushes shouldn't be wearing that quick. I like copper brushes so far, the harder material of the silver brushes will wear your armature faster. Personally I hate to have to cut and clean my armature and the wear on the copper brushes is minimal at 12 hrs in. Though my motor is the Torquemaster Pro 27T |
11-27-2013, 05:55 PM | #7 |
Check your timing, 6 to 12 degrees advance is best. Forward should be faster than reverse. . I've seen kids wear out brushes in 30 minutes that I run 10hours, its more about driving style sometimes.
11-27-2013, 06:59 PM | #8 |
Is there a quick tut on advancing the motor? It was set to 0 deg stock but I did notice the two set screws had backed out a bit. Timing could have shifted?
11-27-2013, 07:07 PM | #9 | |
| Re: 27 turn TorqueMaster Expert 540 Quote:
And I think zero timing is what HH sends the motors out with..i don't think it moved if it was at zero Not with all motors but in your case it should be. NOTE: not all motors have the same timing marks..so make sure of that...Some have 4 smaller lines before a larger one..which usually means each small line is 2 degrees. Last edited by 6sharky9; 11-27-2013 at 11:34 PM. | |
11-27-2013, 07:27 PM | #10 |
| Re: 27 turn TorqueMaster Expert 540 |
11-27-2013, 11:27 PM | #11 |
One tick mark is 12 degrees. 540 Brushed Motor Care, Installation, and Troubleshoot | The Search for Power. A motor guide |
11-27-2013, 11:41 PM | #12 | |
EDIT:Nevermind..im guessing as torque motors for trails and crawling why would you need to time it the other direction..lol Last edited by 6sharky9; 11-27-2013 at 11:48 PM. | |
11-27-2013, 11:48 PM | #13 | |
11-27-2013, 11:49 PM | #14 |
Old racing leftovers. Ccw pinion spin standard. The other direction is reverse and you get one mark. .
11-28-2013, 03:45 AM | #15 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
What about trying a lighter spring on the brushes would that help? Does a lighter spring also reduce drag brake?
11-28-2013, 06:02 AM | #16 | |
MOA's will have 1 motor that rotates opposite the other, scalers may have had the trans flipped. Yes, you will drop mechanical brake if you go to a lighter brush spring. | |
27 turn TorqueMaster Expert 540 - Similar Threads | ||||
Torquemaster expert 13t vs crawlmaster pro 13 vs torquemaster pro 27t | cooperDG123 | Electronics | 6 | 05-08-2013 12:30 PM |
TorqueMaster Expert motor question | TLT-ROCKER | Electronics | 7 | 12-11-2012 05:34 PM |
HH 35t Expert 540 Brushed Motor | Twist n Broke | Electronics | 3 | 02-17-2012 11:30 AM |
TorqueMaster Expert 540 | ickabob | Axial Wraith | 0 | 11-26-2011 09:38 PM |
