12-03-2013, 08:49 AM | #1 |
Newbie Join Date: Sep 2008 Location: Upper Deerfield
| ESC Glitch
On my Wraith I have a reedy 17 turn motor and a Tekin FX-R speed controller with a Savox SA-1230SG servo and a 2 cell lipo. When running the Wraith at any speed it will suddenly loose power. Just for a second then power will come right back. It happens whether I'm going straight or turning so I don't think it's the servo. Any ideas?? Thanks |
12-03-2013, 10:33 AM | #2 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: ESC Glitch
Do you have a external BEC? If so all servos over 200 oz. require that you get one BEC. Also you could need a voltage regulator for your receiver, this can work there only 6 dollars from spektrum. Also if you don't have a BEC Castle Creations makes 10 amp for only 21.00. This happened to me a long time ago, my receiver was fried so I went with a Futaba system, but start with the BEC or voltage regulator and go from there, hope this helped, - axial 4x4 crawler
12-03-2013, 10:51 AM | #3 |
| Re: ESC Glitch
Thanks I'll give that a try. my LHS owner insists I don't need a bec with the tekin. Just one more question, if it's my servo why does it do this when there are no steering inputs?
12-03-2013, 11:08 AM | #4 |
Quarry Creeper Join Date: Jun 2010 Location: Farmington
| Re: ESC Glitch
Your FX-R might need a firmware update? Also, check and see what your low voltage cutoff is set for and that your FX-R is configured for the correct lipo mode. Is your esc getting hot and flashing any LED's when it looses power? If so, maybe double check wiring/solder joints and that the brushes on your motor are in good shape.
12-03-2013, 09:51 PM | #5 | |
| Re: ESC Glitch Quote:
How old is the motor, has it had a lot of runtime? What capacity are your batteries as well as the "C" rating? Looking to see something like "2S, 2000mah, 25C". What battery connector? If it's a Tamiya, that could be the issue. | |
12-05-2013, 12:16 PM | #6 |
| Re: ESC Glitch
Neither the motor or speed controller get hot 1800 mah 25c 2 cell lipo ec-3 contectors Motor doesn't have a lot of run time. The esc is maybe 5 or 6 years old so there may be some issues there. I recentloy moved the esc to a better position with more air flow it was getting warm in the former location. Thanks for the help |
12-09-2013, 07:17 AM | #7 |
| Re: ESC Glitch
shakenadril is the winner low voltage cutoff was wrong Thanks for all the help |
ESC Glitch - Similar Threads | ||||
M2 dig esc with external BEC glitch | Elliott000 | Electronics | 8 | 07-30-2011 07:06 PM |
Stock Ex/Rx and ESC + CC Bec =Glitch !?! | Big Pitt | Redcat Crawlers | 21 | 05-08-2011 07:15 PM |
Dual ESC Glitch During Frt Dig | Monstergt | Electronics | 2 | 02-06-2011 06:23 PM |
Glitch Glitch GLITCH!!!!!!! | rccrawler89 | Electronics | 9 | 12-23-2009 06:41 PM |
No Glitch ESC | Yugiro | Electronics | 2 | 02-04-2008 06:38 PM |
