12-06-2013, 10:49 AM | #1 |
Newbie Join Date: Feb 2013 Location: Toronto
| Difference between cheap and expensive esc
For a Crawler using a 35T-55T motor you obviously don't need to worry about the motor limits (10T, 12T, 15T etc) So what's the difference between a cheap $30 ESC for a brushed system and an expensive one for $120? Keep in mind that both esc's have the same functions, forward, reverse and drag brake. If both esc's give the same function why would you need one that's over twice the money? Maybe a good example is like a Dynamite DYN4925WP its a 15T limit which doesn't matter, its for brushed which is fine, and its waterproof which is a bonus. It can be had locally for like $30 and I don't need to worry about shipping. It also has forward, reverse and brake. So why is a expensive Novak worth the extra $70 for the same functions? As you may be able to tell im pretty new to this stuff lol |
12-06-2013, 10:53 AM | #2 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Re: Difference between cheap and expensive esc
Drag brake, Reliability, Internal BEC, Programability. I suggest: Holmes Hobbies LLC You just missed his black Friday sale with this esc for $67 If you watch the sale area, you can find FXR's and BRXL's for between $60-70 Used |
12-06-2013, 10:59 AM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Buy the $30 Dynamite AND a used HH BRXL. Try both and report back. We know what you're gonna say.
12-07-2013, 04:51 AM | #4 | |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| Re: Difference between cheap and expensive esc Quote:
12-07-2013, 05:52 AM | #5 |
Newbie Join Date: Aug 2012 Location: saline
I've also noticed that more expensive esc's are a little bit smoother than the cheaper ones.
12-07-2013, 06:43 AM | #6 |
Biggest thing you need to be sure of is whether the ESC you're looking at has "drag brake" and not just "brake". Electronics made me very skeptical when I first got into the hobby, but once you finally bite the bullet and pick up some quality components you won't ever go back. Your rig will be smoother, more powerful, stop when you want it to, and hold in place when you want. The more expensive units are more efficient at producing the power you need also. |
12-07-2013, 06:49 AM | #7 | |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
I bough a super elcheapo esc from china, it felt like forward had 6 steps to full throttle, neutral was 1000% full brake, and reverse had about 4 steps. Then I got into Mamba Max Pro's and I'll never do another cheapo esc again. | |
12-07-2013, 07:39 AM | #8 | |
12-07-2013, 08:16 AM | #9 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Difference, with everything being the same, is brand name.....typically. Consider who built the ESC that you're looking at. Is it made by a reputable builder? Does it have the functions needed? Is it the exact same as another ESC but has a different brand name? If I were in your shoes, I would run a stock AE-2...made by castle creations has all the functions needed, durable, reliable, programmable, lovable, and you can't beat the customer support! Biggest option differences, as already stated, would be drag brake and BEC. |
12-07-2013, 09:22 AM | #10 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
Buy once or buy twice. You might get a great deal at $30 or it might be a Chinese turd made as cheaply as possible. Spend a little more and know your getting a proven part that will do the job and last.
12-07-2013, 09:44 AM | #11 | |
Also look at runtimes, cheaper ESC's likely will waste more power than a better ESC. This will eat through a battery faster. Most spec's will show the loss although it may be hard to find. Will it be "night & day"?, maybe not, but there will be a difference. | |
12-07-2013, 01:27 PM | #12 |
| Re: Difference between cheap and expensive esc |
12-07-2013, 01:42 PM | #13 |
Appreciate all the help guys.
12-07-2013, 02:01 PM | #14 | |
Yup I like my AE-2 and they can be had for cheap. I have yet to hear a single bad thing about a brxl and it's on my list of things to buy since it has a wicked brake and can handle 6S. I'm a fan of the castle SV-3 too since it can be used brushed or brushless easily enough. | |
12-07-2013, 02:01 PM | #15 | |
Rock Crawler Join Date: Aug 2013 Location: Central Coast
12-08-2013, 06:50 PM | #16 |
12-08-2013, 11:43 PM | #17 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
A traxxas version of MMP is only about $67 on ebay....
12-09-2013, 02:24 AM | #18 |
I agree with most/all replies above. I started with a Dynamite Tazer 10T ESC, and it was broken in less than a year. Not due to abuse or overloading the BEC, mind you! Its lack of drag brake wasn't an issue since I have worm drives. I replaced it with a MMP which was the right thing for me, as I was transitioning from brushed to brushless a bit later on (again due to the worm drives). But it was also the right thing for me not to buy the MMP with the crawler! 1. I couldn't afford it at the time. Cash management IS part of the equation! 2. The satisfaction of knowing I (now) have the right stuff wouldn't be there had I not got the "bad" equipment first. IMO it can be better to start cheap, find out what's missing/wrong with it for YOU, and then get something that fit YOUR needs/requirements! With a bit of luck some of the cheap equipment will be good enough for you. (For me a cheap Turnigy 3/5A BEC is no worse than a Castle 10A BEC, and by some aspects even better.) |
12-09-2013, 03:27 AM | #19 |
| Re: Difference between cheap and expensive esc You gotta get one man...it's a badass esc. I'm running one on 4s with a 35T...absolutely dead smooth and with the gearing I'm running, turns dead slow too...like comp crawler slow. Love it!! One day I would like to do a wraith using the brxl on 6s and sand tires. That would be cool as hell on the beach!!
12-09-2013, 08:50 AM | #20 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
I have a brxl and an sv2 programmability is awesome on both, since the drag brake on the tazer is always set to 100% and I also like to play around with throttle curves
Difference between cheap and expensive esc - Similar Threads | ||||
Least expensive crawler esc ? | builder | Electronics | 11 | 05-28-2013 07:24 PM |
Is there really a Difference in an ESC? | FordFixer | Electronics | 9 | 01-18-2012 10:17 AM |
Cheap links tech article was expensive. | bud212002 | Axial AX-10 Scorpion | 10 | 11-30-2008 10:43 PM |
