12-08-2013, 07:52 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Internal BEC's
Not being electronics minded at all, I have a question about ESC internal BEC's. Why don't the ESC manufactures just install say a 7amp internal BEC in their ESC's and eliminate the need for an external BEC in most cases. Seems it would be an easy fix for a lot of issues I read about here and eliminate the extra electronics of the external BEC. Thanks
12-08-2013, 08:07 AM | #2 |
| Re: Internal BEC's
Cost is the likely biggest reason. Size, of the ESC, is the 2nd thing. A better internal BEC can add a lot to the size of the ESC. Outside of crawlers, most rigs use lower torque steering servos, thus the internal BEC is fine (up to ~200inoz). The Holmes Hobbies BR-XL has the best internal BEC, but even that has it's limits. For me, I like having the external BEC, if I fry it I replace a ~$20 external BEC, not a much more expensive ESC. The external BEC (Castle 10A) is also adjustable, so I can pick what I want for a voltage. Edit... The internal BEC's in ESC's are set to allow working through the RX without damage to the RX. If you overvolt or overamp the RX traces, you can burn them off which kills the RX. There have been some cases, on this forum, where people have killed RX's by running too much load through the RX. I don't remember what RX's or the volts/amps used that killed the RX's. Last edited by Charlie-III; 12-08-2013 at 09:24 AM. Reason: Added info. |
12-08-2013, 08:52 AM | #3 | |
| Re: Internal BEC's Quote:
12-08-2013, 09:02 AM | #4 |
Quarry Creeper Join Date: Jun 2010 Location: Farmington
| Re: Internal BEC's
I ran my Tekin RS gen2 bec which is adjustable for 6.0V or 7.4V and 5.5A on a 400inoz Savox servo in my wraith. I was running a Tekin ROC 412 3100kv on it. If I was going to do all day runs with it I would buy the RX8 Gen2 which has a 7A BEC built in. **Note** Its much cheaper to buy a MMP and Castle BEC than an RX8, but the option is there if you really want a built in BEC. Last edited by shakemandril; 12-08-2013 at 09:05 AM. Reason: see note |
12-08-2013, 09:24 AM | #5 |
| Re: Internal BEC's
Added to my earlier post.
12-08-2013, 09:40 AM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Internal BEC's
Another reason not to use the internal bec is the fact that it adds additional heat to it, which you really don't want. For a $20 CC bec, you will save your esc from having to work harder than necessary and you can dial in the exact output voltage that you want, instead of being stuck with what the esc puts out. For example, take the HH brxl. Awesome esc, however it's internal bec only puts out 6v. My servo and winch both run on 7.2v, so I have the CC bec set at 7.5v out to the Rx so everyone's happy.
12-08-2013, 08:33 PM | #7 | |
12-08-2013, 08:55 PM | #8 |
| Re: Internal BEC's |
12-08-2013, 09:07 PM | #9 |
Internal BEC's - Similar Threads | ||||
Dual CC BEC's??????? Can it be done? | day215 | Electronics | 2 | 02-12-2011 10:09 AM |
2 CC BEC's or just 1 ?????????????? | slashbasher | Electronics | 1 | 08-14-2009 04:54 PM |
