12-08-2013, 12:44 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Walters, OK
| Electric motors burning up in cold weather
to start off i am using holmes hobbies motors, and forgive me if this question has been asked before, but i live in Oklahoma and we just got some snow. My dad and I have been driving our scalers outside and my first motor, a HH 35t torque master, burnt up in about 10 minutes, so i replaced it with a HH sport, which had the same results, and my third motor as well. My father, who is running a similar set up on a 3S has had no problems. I am running a 4S and i have a 72 mhz radio, i have had a severe glitching problem. I have concluded that my motor spinning back and forth repeatedly and the voltage being spiked has resulted in this problem. any help would be appreciated, Thanks in advance.
12-08-2013, 12:56 PM | #2 | |
| Re: Electric motors burning up in cold weather Quote:
12-08-2013, 01:11 PM | #3 |
so you think it is the glitching ? i thought so also but wanted to hear everybody else's thoughts. I'm sure the 4S doesn't help either. Thanks.
12-08-2013, 01:15 PM | #4 |
Glitching and 4S are for sure not helping. Glitches are brutal and 4S means much more frequent maintenance. |
12-08-2013, 05:29 PM | #5 | |
Also, when upping the voltage to 4S, you should have changed gearing, either lower tooth count pinion or higher tooth count spur. As Holmes himself says, "Volt up, gear down". | |
12-09-2013, 02:05 AM | #6 |
Running in snow typically adds drag, so if your setup worked fine (with a warm motor) on bare ground the snow might be killing it! (Happened to me!) |
12-09-2013, 09:07 AM | #7 |
| Re: Electric motors burning up in cold weather |
Electric motors burning up in cold weather - Similar Threads | ||||
Cold Weather Crawlin' | Fumbles | Videos! | 1 | 01-05-2013 09:01 PM |
Cold weather packs | Docwolf | Electronics | 11 | 09-27-2012 10:24 AM |
Lipos and cold weather | brokennib | Electronics | 4 | 02-20-2011 01:48 PM |
Painting in Cold Weather | Jmterminator | Paint and Body | 22 | 12-07-2008 06:42 PM |
Oli wt. for cold weather | drumbeater | General Crawlers | 4 | 12-18-2007 02:48 PM |
