12-09-2013, 08:25 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: almuņecar- espaņa
| Problem with dual tekin
hello and put two tekin fxr in my XR10 the problem is that when the front motor is accelerated faster than the engine Rear. I have a station flysky GT3C rescheduled. sorry for my English
12-09-2013, 08:35 AM | #2 |
| Re: Problem with dual tekin
Calibrate both escs with the radio and verify that your motor timing is correct on both axles.
12-09-2013, 08:55 AM | #3 |
is calibrated both esc with the transmitter and the front engine remains the same is faster than the Rear
12-09-2013, 09:04 AM | #4 |
| Re: Problem with dual tekin |
12-09-2013, 09:36 AM | #5 |
yes, two time
12-09-2013, 09:38 AM | #6 |
In reverse which motor is faster?
12-09-2013, 10:09 AM | #7 |
the front also, it's like the front to reach more power
12-09-2013, 05:24 PM | #8 |
Do both motors have the same tooth count pinion gear?? I believe stock is a 14T pinion, if the rig was run with a single ESC, or, a radio that can't do dual ESC mixing people sometimes use different tooth pinions to deal with clod stall. |
12-10-2013, 09:22 AM | #9 |
holmes has engine sprocket 45t and 15 in the two cases
12-10-2013, 06:05 PM | #10 |
Rock Crawler Join Date: May 2012 Location: Upland
Switch out the esc and then see how it acts Sent from my PG86100 using Tapatalk |
12-10-2013, 06:29 PM | #11 |
Quarry Creeper Join Date: Nov 2013 Location: Pittsburgh
do you have the tekin hotwire? it sounds to me that the firm wear on the esc are different. if they are different that will cause one motor to spin faster than the other. I had the same problem with mine when I put dual tekin fxr-pro on my super, and when I hooked them up to my computer with the hotwire I found out that they had two different fire wears on them. so check that and make sure that both esc are have the same settings and that should fix the problem, well atleast it fixed mine.
Problem with dual tekin - Similar Threads | ||||
Dual fxr problem... | KustomKreeper8606 | Electronics | 20 | 08-11-2013 05:50 PM |
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
Tekin Problem or Radio Problem? | Harvo | Electronics | 8 | 07-30-2010 06:02 AM |
Dual Sidewinder Programming Problem | JeremyH | Tamiya Clod Buster | 8 | 04-15-2008 08:11 AM |
