12-13-2013, 10:22 PM | #21 | |
| Re: How long will a LiPO retain its charge Quote:
12-15-2013, 05:02 PM | #22 |
Pebble Pounder Join Date: Jul 2013 Location: matwin territory
12-15-2013, 05:03 PM | #23 |
My "pos" has lasted fine for 3 years. Also with it being cheap I don't worry about losing it.. A good investment I guess. I (or you) could always go to the lhs and ask them to check the battery if you feel the need.[/QUOTE] I stand corrected, ill have to keep it in mind then |
12-15-2013, 05:06 PM | #24 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: How long will a lipo retain its charge |
12-15-2013, 05:07 PM | #25 |
| http://www.maxamps.com/Lipo-13500XL-74-Pack.htm If you could even use this in a wraith, scx10 etc how long would something like that last, as far as charge goes, guestimated ? Also will the c rating in a lipo greatly effect the performance of a trailer/crawler because this bad boy has like 100-120 something like that |
12-15-2013, 05:09 PM | #26 |
12-15-2013, 05:12 PM | #27 |
Dude, don't even waste your money on that lipo. However, 13,500mah would last a loooong time. As far as C rating, you really don't need more than 30-40C.
12-15-2013, 05:13 PM | #28 |
12-15-2013, 05:15 PM | #29 |
Why u no rike max amps? and what's the issue with a high c rating because I haven't had that question answered yet?
12-15-2013, 05:20 PM | #30 | |
My biggest money crap Shute is the merv god I hate that thing, with all due respect to traxxas, they really let the ball down on that thing, every time I drive it something breaks so I have about $400 dollars of replacement parts I did t want to spend money on in the first place... Finally I gave up, so P.Oed, | |
12-15-2013, 05:23 PM | #31 |
12-15-2013, 05:30 PM | #32 | |
| Re: How long will a lipo retain its charge Quote:
5000mah 50C...250 amps out With most lipo's, the amp burst rating is double the constant. As C rating goes up, so does the weight. | |
12-15-2013, 05:37 PM | #33 |
So it wouldn't be bad to have a high c rating just not necessary? Also what would be the general target price for a good quality lipo that isn't over priced, and another question would that lipo work fine in a wraith, scx10 rigged for trailing?
12-15-2013, 05:53 PM | #34 | |
Since you're looking at high mah packs, a 20C is fine, 40C is nice. | |
12-15-2013, 05:57 PM | #35 |
Ok makes sense now, thanks
12-15-2013, 05:59 PM | #36 |
Would a 750 mah battery be used for something like a Moa comp crawler or a super class ? And would they be the packs that you have one on each axle Velcroed in ?
12-15-2013, 06:21 PM | #37 |
| Re: How long will a lipo retain its charge Between $20 to $40 each
12-15-2013, 06:23 PM | #38 |
12-15-2013, 06:59 PM | #39 | |
In my 2.2 MOA, I run 325mah-450mah 3S LiPO packs, one at a time and I can do maybe 2 courses but usually swap packs after each course. | |
12-15-2013, 07:01 PM | #40 |
I'm a newb when it comes to comp crawlers so is there any kind of general rule on how long it takes to complete a course? Or not
How long will a lipo retain its charge - Similar Threads | ||||
How long to charge lipo | WestTxRc | Electronics | 8 | 11-02-2011 04:42 PM |
Lipo won't charge | Serolf | Electronics | 4 | 02-19-2011 09:36 PM |
How long do I charge it? | Zapper2003 | Electronics | 5 | 04-01-2010 04:03 PM |
storage charge a lipo | kmrunner | Newbie General | 5 | 01-25-2010 05:07 PM |
Lipo charge help needed | greenjeeper92 | Newbie General | 1 | 01-22-2010 12:48 PM |
