12-16-2013, 06:10 AM | #41 | |
| Re: How long will a lipo retain its charge Quote:
G6 courses can be quite long with a fair amount of time close to full throttle. | |
12-16-2013, 09:39 AM | #42 |
Pebble Pounder Join Date: Jul 2013 Location: matwin territory
Do you have to run a small mah pack ( like its in the regs or something) or is it just not necessary to run a higher mah pack |
12-16-2013, 01:40 PM | #43 | |
Since most comp rigs are tight on space & we try to keep mass (weight) where we want it, small packs make it easier. The, "I'm going to be lighter than you" crowd is going even lower in capacity/mah. My packs are on the high side (capacity/mah wise), but I also know that they drop in performance over time/charge cycles. If I start a little high, they will work on a course longer. PS, you know, YOU could read the rules so you know. Helps when doing a rig for a class so you don't do something "less than desirable". | |
12-16-2013, 03:49 PM | #44 |
Alright Ill do some searching and read the regs because it all sounds interesting, thanks for the info!
How long will a lipo retain its charge - Similar Threads | ||||
How long to charge lipo | WestTxRc | Electronics | 8 | 11-02-2011 04:42 PM |
Lipo won't charge | Serolf | Electronics | 4 | 02-19-2011 09:36 PM |
How long do I charge it? | Zapper2003 | Electronics | 5 | 04-01-2010 04:03 PM |
storage charge a lipo | kmrunner | Newbie General | 5 | 01-25-2010 05:07 PM |
Lipo charge help needed | greenjeeper92 | Newbie General | 1 | 01-22-2010 12:48 PM |
