12-14-2013, 10:13 AM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Colorado Springs
| help diagnosing esc trouble
Wraith RTR poison spyder with about half a battery pack of use (it came out of the box and immediately started getting troubleshooting.) The problem: When I try to climb a stair I get about 1/4 tire turn and it will lose all power and just flop, then repeat. Once it powered itself off completely and I had to unplug the battery and re-plug it back in. It also has very noticeably less power and speed than my scx-10, even running the same motor/battery in the scx, putting them in my wraith and running it back to back. I have searched and I found: Check battery charge, I charged and even tried different battery packs. Check solder on batt connection, (cut and re-soldered 3 new connections). Check motor to esc connections. They were literally wobbly loose, so I crimped the female connecter a little so it was tight, and then soldered the connection, still having the same problem. Check the motor, maybe it needs rebuilt: Nope, I have tried 3 different motors, 1 used known good, 1 new in the rtr kit, 1 broken in and installed. Am I missing anything? Does anybody else have another suggestion for troubleshooting? Or do I need to wait until Monday and call axial support? Thanks for any suggestions. |
12-14-2013, 10:18 AM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: help diagnosing esc trouble
Have you noticed any steering troubles? Maybe try a different servo? |
12-14-2013, 10:35 AM | #3 |
The steering does seem slow and weak compared to the same (stock) servo in my scx10, although I'm using an xl-5 in it which has a built in 6v bec. I was inspecting the servos and they both have what I would call an alarming amount of shaft end play. I'll run a backup servo and try again. |
12-14-2013, 03:02 PM | #4 |
I snagged another esc from a friend and it's performing as I expected. |
help diagnosing esc trouble - Similar Threads | ||||
Esc trouble | T.CLAUNCH | Axial AX-10 Scorpion | 5 | 07-14-2013 12:10 PM |
esc trouble | fastlane | Electronics | 1 | 07-31-2011 08:26 PM |
Esc trouble ? | Skier | Duratrax Cliff Climber | 1 | 03-29-2011 07:56 AM |
having trouble with esc i think need help | macclen30 | Electronics | 4 | 10-07-2010 03:14 PM |
