12-15-2013, 06:48 PM | #1 |
Pebble Pounder Join Date: Dec 2012 Location: portland
| BR-XL esc wiring
From what I have read it is best to wire in parallel, rather than series. I have seen some diagrams, but would like to see some pics. I will be doing this on my redcat rs10, using the one esc to run both motors. Thanks.
12-15-2013, 09:15 PM | #2 |
| Re: BR-XL esc wiring Photoclub - Secure pictures online I hope this link works. I did a lot of searching and this is the best I could come up with.
12-15-2013, 09:28 PM | #3 |
Ok, I have soldered up some y connecters for my motors. I have a couple of questions. The BR-XL has a black wire and a white wire. Is the white wire the positive, and black negative? Also BR-XL instructions say to remove the red wire to the receiver plug before installing. I have removed the red wire and folded over and taped like the manual says. Why does this need to be done? Also may do a dig switch at a later time. Pics of your set ups would be helpful?
12-15-2013, 09:49 PM | #4 |
Rock Stacker Join Date: Sep 2013 Location: Sandy
yes white + black -....u only need to remove the red wire if you're running a BEC
12-16-2013, 01:34 AM | #5 | |
| Re: BR-XL esc wiring Quote:
If you're not running an external BEC into your receiver, this still needs to be done on one of your ESCs, so the two internal BECs don't fight each other. | |
BR-XL esc wiring - Similar Threads | ||||
Wiring two different esc ? | builder | Electronics | 3 | 04-30-2013 06:46 PM |
dual esc wiring? | john. | Newbie General | 7 | 01-10-2012 08:56 AM |
esc wiring help | boohoo | Losi Micro-Rock Crawler | 7 | 03-26-2011 10:45 PM |
ESC Wiring | jcraw | Redcat Crawlers | 4 | 02-25-2010 05:51 PM |
Help with wiring new esc | 09xD | Duratrax Cliff Climber | 16 | 07-30-2009 04:21 PM |
