12-17-2013, 09:58 PM | #1 |
Pebble Pounder Join Date: Oct 2012 Location: Georgia
| Never Wet?
I heard of this stuff and was wondering if any of you "Old Times" out there tried it and if so what do you think? I ordered me the set up and will be doing a review of it. With my test subject "The SCX10 Bully Beast" "You'll find it in the SCX10 section." It might be awhile ....since shipping here to APO takes a while. LOL Thanks, Pmoss |
12-17-2013, 10:10 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Never Wet?
Looks like cool stuff!! http://www.neverwet.com/ |
12-17-2013, 10:11 PM | #3 |
| Re: Never Wet? |
12-17-2013, 10:17 PM | #4 |
| Re: Never Wet?
How much does that stuff cost??
12-17-2013, 10:20 PM | #5 |
| Re: Never Wet?
I haven't tested it's submersible abilities yet... but I did spray all my circuit boards with it. Some have said that it doesn't last and requires re-coating after a period. Or chit will fry. But that could be with a fault in its application rather then a failure of the product. I did 4 coats of each part 1&2 on my Servo, ESC, RX and BEC boards. More then what is required according to directions. I did further waterproofing by installing all the electronics in a sealed box. My ESC is the only electronic unit that relies solely on the NeverWet protection. As that is mounted externally on the chassis. Others here have said it worked fine for them. I've done some splash abouts without issue... but haven't submerged the chassis fully yet. I wasn't going to tempt fate with it... until I have some replacement electronics. ~just in case~ Last edited by TacoCrawler; 12-17-2013 at 10:24 PM. |
12-17-2013, 11:08 PM | #6 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Never Wet? |
12-18-2013, 09:58 AM | #7 | |
| Re: Never Wet? Quote:
I am on the CorrosionX band wagon. Guys say it is good too. The only down side to CorrosionX is that it leaves the parts wet with the stuff. It doesn't dry but that might be its secret to waterproofing. NASA apparently uses the stuff. CorrosionX | |
12-18-2013, 11:03 AM | #8 |
| Re: Never Wet?
Conformal coating ftw. Why not do it the way the OEM does it instead of hoping products that aren't made for electronics will work?
12-18-2013, 11:13 AM | #9 |
| Re: Never Wet?
I have conformal coating but doesn't it add bulk to the components? I bought 2 cans of good stuff but am lazy to try it yet. Also it is too cold up here now to be spraying outdoors. I have no heated area to go to without begging..lol The stuff I bought is from MG Chemicals called Silicone Conformal Coating. |
12-18-2013, 11:21 AM | #10 | |
12-18-2013, 11:48 AM | #11 |
| Re: Never Wet?
Okay well too late for me to buy the brush on stuff...lol. I have the spray on kind. I will try it on other projects but for now I have CorrosionX on all my stuff other than the waterproof BRXLs I have. I think CorrosionX is impossible to get off so conformal coatings would just slip off those now...ooops. I have seen proof that CorrosionX work on ESCs. I fell for it |
12-18-2013, 02:00 PM | #12 |
Rock Stacker Join Date: Sep 2013 Location: NW arkansas
Be careful with the corrosionx. I fried my mamba max pro last week after playing in the snow and relying on the corrosionx... I will be applying conformal coating this time around Sent from my SAMSUNG-SGH-I747 using Tapatalk |
12-18-2013, 03:26 PM | #13 | |
I will take my chances for now but thanks again for the info. | |
12-18-2013, 04:14 PM | #14 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
| Re: Never Wet?
Another happy MG conformal coating user here. Great stuff!
12-18-2013, 04:28 PM | #15 | |
Moderator Join Date: Jan 2004 Location: chicago
ive used the spray on conformal coating on many servos, esc's, bec's, and sensor boards. its super thin and for sure runs under components and in areas you cant directly spray onto. i would like to try the brush on stuff someday, just waiting to run out of the spray. | |
12-18-2013, 05:33 PM | #16 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Never Wet?
Not only is it made specifically for this type of desired protection and proven to do so, conformal coating is also a less expensive option. Sure, if you have neverwet already then try/use it - but if you're buying, then the conformal coat is a no-brainer IMO for protecting your electronics investment.
12-19-2013, 07:50 PM | #17 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
| Re: Never Wet?
I've been using plasti-dip for years and its never let me down, but its kinda bulky. As there are so many different products out there, can someone please provide a link to the exact product being referred to as conformal coating? |
12-19-2013, 08:08 PM | #18 |
Quarry Creeper Join Date: Sep 2012 Location: Emmaus, Pa
| Re: Never Wet? |
12-19-2013, 09:06 PM | #19 |
| Re: Never Wet?
The 55ml size comes in a bottle with a brush applicator inside already. MG Chemicals 422B Silicone Conformal Coating: Amazon.com: Industrial & Scientific |
12-19-2013, 09:31 PM | #20 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: Never Wet?
Another yes for the conformal coating. I've used it on my RS Pro and Pro4 and have had my Class 3 Trooper with 6" of water over the top of the cab. I use it as my secondary protection though, I always balloon my electronics. I just can't trust $300 of electronics with only a spray on product.
Never Wet? - Similar Threads | ||||
Never Wet | jacks766 | Tools, and Procedures | 12 | 12-06-2013 03:29 PM |
What can get wet? | XcrawlerkidX | Axial SCX-10 | 7 | 11-16-2010 07:29 AM |
Getting Wet | dbb888 | Tamiya CR-01 | 16 | 09-09-2008 11:30 AM |
Wet, wet, wet | wallaz | Videos! | 6 | 10-10-2007 10:24 AM |
