Thread: as-3 servo into a winch servo?
Old 12-20-2013, 12:46 PM   #1
Default as-3 servo into a winch servo?
Im trying to convert a as-3 servo into a winch. I am running a 3pm radio and my steering servo will center using the 3 speed setup for the radio. The as-3 will continue to spin and will only change direction and wont center so to speak. Anyone have any ideas to get to work as a winch?
turtleone is offline   Reply With Quote
Old 12-20-2013, 01:03 PM   #2
Default Re: as-3 servo into a winch servo?
Not the same servos... but purdy much the same deal
How to Make a Servo Winch - YouTube
http://youtu.be/nRfOCV_xu2s
http://youtu.be/SK8mhnEzcvY
TacoCrawler is offline   Reply With Quote
Old 12-20-2013, 01:12 PM   #3
I have pulled the pin out and the plastic fork piece. Thats why when I plug it in it continues to spin. I am lookung in how to get it to stop turning so the line would stop spooling.
Old 12-20-2013, 01:21 PM   #4
You need adjust and center the potentiometer.
The videos show different options of that.
Most seem to use CA glue to secure that once centered.
btw...
Even tho' the AS3 is metal geared...
Axial installed plastic bushings on the output gear.
That is a fail... and will likely result in poor gear mesh or breakage later on.
Changing out the plastic bushings to ball bearings
will offer a more proper gear mesh and for a longer period of time.
Old 12-20-2013, 01:23 PM   #5
Oh ok thanks for the info!
Old 12-20-2013, 03:44 PM   #6
Agreed, either center the pot in order to use the stock board or rip out the internal board altogether and run an esc as a controller.
Meatwad is offline   Reply With Quote
Old 12-20-2013, 04:18 PM   #7
You have a link to a "thread" pertaining ?
I'd like to see how this is done.
Old 12-20-2013, 04:26 PM   #8
I would talk to heyok from the forum here. his controller seems fool-proof. that's the route I'm going when I build mine.
just my .02
warren is offline   Reply With Quote
Old 12-20-2013, 09:18 PM   #9
Haven't seen one. Pretty straight forward though, once the stopper pin from the main gear and electronics are removed from a servo it's essentially a motor and transmission. Hook the motor side of the esc to the servo motor and figure out the battery side, done deal.
Old 12-20-2013, 09:36 PM   #10
btw...
To add to this ,the rebuild kit for the traxxas 2075 servo has the correct size bearings for the conversion...if you can get the bearing size you may can just get bearings for less..the rebuild kit is under $10 though if im not mistaken.
6sharky9 is offline   Reply With Quote
Old 12-21-2013, 04:32 PM   #11
Just throwing this in here because it seems appropriate:
Another servo winch building tutorial
heyok is offline   Reply With Quote
as-3 servo into a winch servo? - Similar Threads
Jevne Batt./Servo Plate With Servo Winch Installed? BodiBuilt Axial SCX-10 0 12-11-2012 05:19 PM
