12-22-2013, 10:18 AM | #1 |
Pebble Pounder Join Date: Sep 2007 Location: Lowell
| Cc bec help please
I have a cc bec that when hooked up according to castles instructions it never shows a green light... And only reads .91 volts conning out of output plug. When I plug it into by castle link the greed led on the bec turns on but it will not connect. Sent from my I wait for it ...Phone using Tapatalk |
12-22-2013, 10:24 AM | #2 |
| Re: Cc bec help please
What is it connected to for power? Usually it's on the ESC input wires, it gets it's power when a pack is plugged in. As to programming, if it's connected like above, you will likely need a pack plugged in (to program the BEC) since the PC USB connection (through the Castle Link) can't provide enough power to bring up the BEC and the ESC. |
12-23-2013, 10:41 AM | #4 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
I copied this right from my CC Link software program. Verify that you have a green USB connection status in the lower left hand corner of the Castle Link screen. If not, go to the Castle Link FAQ section regarding loading the driver. If it is green but the ‘Device Connection Status’ light stays red, the USB port may not be able to provide enough current to power the CC BEC. This generally happens when you have soldered the ESC and BEC leads together. To fix it plug the BEC into the Castle Link, and then plug a battery pack into the ESC/BEC battery connection. If you are still having problems connecting please contact our customer support team at: support@castlecreations.com System Requirements: Castle Link is compatible with Windows 2000, XP, Vista, and Windows 7.* *Windows Vista and Windows 7 require a specific installation process. See our Castle Link FAQ page for more information. Macintosh users may take advantage of software such as Parallels Desktop, VMware Fusion, or Apple's Boot Camp along with Windows 2000, XP, Vista, or Windows 7 to run the Castle Link software, provided the Macintosh has an Intel processor. Macintosh installation is not supported by Castle Creations. |
Cc bec help please - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
