Thread: PL4 setup to run the E-flite efc-720 camers
Old 12-28-2013, 02:19 PM   #1
Default PL4 setup to run the E-flite efc-720 camers
I bought this Camera the other day looking to install it on my Scaler and run it off my fourth channel. So far I cant get it to work correctly... Has anyone used this camera yet? I do know that the remote on the 180qx copter it comes on uses a toggle switch.. Any help would be great.. Thanks,Pat
cherokee pat is offline   Reply With Quote
PL4 setup to run the E-flite efc-720 camers - Similar Threads
Proper Setup / First Run Checklist jbsmith05 Axial AX10 2nd-gen 3 04-02-2013 02:52 PM
You dont need a BEC (if you run this setup) Illeagle Losi Mini-Rock Crawler 22 01-14-2012 10:10 AM
Which setup should i run? ZackMicF Electronics 7 10-15-2011 04:14 PM
little setup run with my Climber 2.2 (it's not a Wraith ;-) nicodrive01 Videos! 2 08-05-2011 01:53 AM
little run down of my setup...thoughts needed phre0n Axial AX-10 Scorpion 3 06-12-2011 10:21 PM
