12-29-2013, 04:09 AM | #1 |
Newbie Join Date: Jul 2010 Location: Australia
| battery help please??
A friend gave me 2 turnigy 2 cell 5000 mha hard case batteries. I needed to change the connection to Deans plugs, so I cut each wire separately soldered it up, all good? No when I connect it to a charger it comes up with a connection break. I have put it in a car and it goes fine. I have a cell tester that plugs into the balance cable, it reads both cells as charged. It does give a funny balance reading but then reads good both cells. Why wont my charger charge? I have two charges same result on both. Have re-soldered the connection still the same. I'm lost am I just a s&%t solderer or is there a problem I'm missing? Last edited by threedogs; 12-29-2013 at 10:29 PM. |
12-29-2013, 04:56 AM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: battery help please??
Possible broken balance wire. When you have the tester plugged into the balance connector, bend the wires around and keep your eye on the readings. A broken wire will prevent the charger from starting.
12-29-2013, 06:27 AM | #3 | |
| Re: battery help please?? Quote:
Try a charge without the balance plug connected & do a plain LiPO charge, not a balance charge. | |
12-29-2013, 06:51 AM | #4 |
Rock Stacker Join Date: Nov 2013 Location: Meridian, Idaho
Check the balancer port adapter as we'll. I have a hitec x4 and one of the balance port adapters fried the 3 cell connection on it. I move it to another adapter and all is good! |
12-29-2013, 10:28 PM | #5 |
Tried a straight charge, no balance port connected same result? Anymore ideas? Just to make things interesting, it will charge through the balance port. Found an old charger I got with my "Twin Hammers" it charges it Ok so far. I'll keep you posted and try to nut it out. My next door neighbour is a bit of an electronics wiz. Ill bash his brain with the problem. THANK YOU so much for your reply's its great to have the help of a wonderful community when you need it. Last edited by threedogs; 12-29-2013 at 10:40 PM. |
12-29-2013, 11:04 PM | #6 | |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Just an FYI. You can plug directly into the balance port on the X4. No need for the adapter. | |
12-30-2013, 02:15 AM | #7 |
I am using a RT 808D it's a multicharger and it's about 4 years old. By "multi" it does different battery types not multiple batteries. The Vaterra charger indicates that the battery is fully charged. I'm gunna chuck it in my Blitz for a minute. Burn some amps and try again. Guy next door said that the voltage in one cell may have been low so the charger failed to recognize it. Again thank you for your help. I love this sight just wish I knew half as much as you guys so I could repay the favour. |
12-31-2013, 12:54 AM | #8 |
Got on to a guy who did battery stuff for the Navy here in Australia. He has explained to me that the fault is in the way the cell are wired. They charge in parallel but discharge in series. So the fault is in the series circuit (I THINK). Anyway for the sake of getting an answer we are going to crack it open and run some tests. And attempt a repair. Will try to get a blow by blow with pics for those who are interested. |
12-31-2013, 03:16 AM | #9 |
Man you have patience!!! I would've just shitcanned it and bought a new one.
12-31-2013, 11:58 AM | #10 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Do you have another charger to try out?
12-31-2013, 02:07 PM | #11 | |
If the balance port is connected (regardless if you select straight charge or balance charge) then the charger will check each cell voltage as well as total voltage (vs. cell count you selected). If something is "out of spec", you will get your error. I've had balance wires break at the cell & get the same error as you. I then do a straight charge through the pack main plug (balance port disconnected) and it charges fine. | |
battery help please?? - Similar Threads | ||||
Battery question...yes, I read the battery thread...twice... | MikeTJ | Losi Micro-Rock Crawler | 14 | 06-07-2011 07:44 PM |
UK Version please - LOSB0862 Battery Charger & Battery. | newth | Losi Micro-Rock Crawler | 7 | 05-26-2010 01:38 AM |
Finding bad battery cells in a battery pack. | ToTheMAXXcrawler | Electronics | 9 | 02-04-2010 10:14 AM |
