12-29-2013, 07:57 PM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| New decased BRXL problem.
Hi all, I need some help trouble shooting an issue I had today. Went out to do some scaling and ran my Jk for a while when the Brxl stopped working after a battery change. I have a GCM Cross Canyon chassis with the motor and tranny up front. Motor is a Brood 35t Vapor that I just rebuilt. Battery is a single 3600 3s. She ran fine for quite a while, maybe an hour, to an hour and a half. I let the rig sit for around 15 min. I went to plug in another 12.5v 3s battery and the Brxl acted like it wasn't communicating with the rx. I went to setup the rx to esc and it failed several times. I only have steering and no throttle, forward or backward. Any ideas. Thanks. |
12-29-2013, 08:45 PM | #2 |
| Re: New decased BRXL problem.
Swap the servo into the RX port 2, see if the throttle trigger moves the servo. If not, it's a radio issue.
12-29-2013, 09:08 PM | #3 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
What type of radio system are you using?
12-29-2013, 09:34 PM | #4 |
Pebble Pounder Join Date: Dec 2012 Location: portland
I am having an issue as well, brand new never used BR-XL. Fully charged nimh battery. I am not getting any servo or motor movement. All I am getting is beeping with flashing green and orange lights. Using stock redcat rs10 radio, not 2.4 . Please help. Also I pulled the red wire to the receiver as directions indicated and taped up with electrical tape.
Last edited by redcatkrawler; 12-29-2013 at 09:37 PM. Reason: missing information |
12-29-2013, 10:11 PM | #5 |
redkat, what are you powering the Rx with?
12-29-2013, 10:15 PM | #6 | |
Quarry Creeper Join Date: Jul 2007 Location: WA
| Re: New decased BRXL problem. Quote:
12-29-2013, 11:26 PM | #7 |
Fixed with red wire. Thank you.
12-30-2013, 12:45 AM | #8 |
Pebble Pounder Join Date: Nov 2011 Location: Kittanning
@stelerzman i have one that does that every now and then.. try plugging it in then wait a sec unplug and plug back in.. like do it twice and see if it arms.. its normally a motor issue. mine was a timeing issue on the motor. sounds dumb but weird shit happens lol.. my esc still doing it after a year.. i just plug and unplug, and replug till it arms.. then it works.. over a year old still fine |
12-30-2013, 05:33 AM | #9 |
| Re: New decased BRXL problem. I'm running an mx3, Airtronics. With is radio I was running it for an hour +. Only thing that changed was the battery.
12-30-2013, 10:26 AM | #10 | |
Did you try another battery? Did you check for cold solder joints to the ESC? | |
12-30-2013, 10:41 AM | #11 | |
I thought about programming the esc back to default setting and going from there, I just haven't done it yet. Do ya think this might work? | |
12-30-2013, 12:40 PM | #12 | |
Can't tell you that is the absolute fix in your case, but mine's been fine ever since. | |
12-30-2013, 02:29 PM | #13 | |
12-30-2013, 07:03 PM | #14 |
I just got home, so it looks like tomorrow is the best time to check this issue out |
12-31-2013, 08:24 AM | #15 |
I just tried switching the servo plug to the throttle channel and the servo move L&R. This tells me the rx is working properly. I switched the plugs back to the correct channel and pulled the throttle and no movement. The esc lights up green when I pull and when I push the throttle the esc lights up red. As far as I know this is what's suspose to happen. Right? |
12-31-2013, 09:21 AM | #16 |
yup, that means it's getting the correct signal, do you have a voltmeter to check the output of the esc? i would try another motor just in case.
12-31-2013, 09:39 AM | #17 |
| Re: New decased BRXL problem. |
12-31-2013, 10:20 AM | #18 |
Well this is disturbing, I just checked the output voltage on the esc, here are the readings. Forward = 12.10volts and reverse = 9.8 volt. I do have the reverse backed down, so the #'s look to be correct. My problem is the motor. Anyway, I'll solder up a different motor and see what happens. |
12-31-2013, 05:30 PM | #19 |
Good news, try any motor just to be sure, sounds like a brush or bad wire in the winding |
12-31-2013, 06:03 PM | #20 | |
