Thread: Scx10 nube
Old 12-31-2013, 06:19 PM   #1
Default Scx10 nube
Hey new to the forum and rc I recently got an scx10 jeep rubicon rtr working on getting theis thing up to snuff but my steering servo makes a noise and twitches a little bit and the truck squeaks bad I fixed it somewhat with wd 40 but can anyone give me some good tips and stuff about my new rig? I'm 20 years old and looking forward to better my truck in crawling!
Stonewallw is offline   Reply With Quote
Old 12-31-2013, 06:31 PM   #2
Default Re: Scx10 nube
Servos (especially digital servos) tend to "hunt" for center when they are loaded (steering wheels on the ground for example). They make buzzing sorta sounds normally. Lifting that end of the rig while powered on usually quiets it down.
Charlie-III is offline   Reply With Quote
Old 12-31-2013, 07:21 PM   #3
Norton's Avatar
My guess is being that it is a RTR your using the stock servo? On the stock servo there is a plastic bushing instead of a bearing on the output shaft. I run Savox 1230 servos on my SCX10 and crawler. (500 oz of torque) It's definite overkill on the SCX10 so far. If it is indeed your servo going out there are much more affordable servos that would suit your needs. I would also stay away from WD40, at least on plastic.
Norton is offline   Reply With Quote
Old 12-31-2013, 08:14 PM   #4
If you are good at bashing, you can open up the stock servo and replace the bushing with a 6x10x3 or 6x10x2.5 bearing.
I ditto the WD-40. It's a petroleum based product and that it bad on any plastic.
Kingmeow is offline   Reply With Quote
Old 12-31-2013, 08:54 PM   #5
what servo ?
what noise ? describe
If the oem RTR AS2...
^ (comment prior)
prolly the bushings (X2) failing on the output gear shaft
gear mesh would become fubar, noise would become excessively worse...
and then the gears will strip or lock up. darn it
replacing the bushings with bearings need occur soon I'll guess.
My 1:1 squeaks and groans as well.
is what happens when you play in the dirt
cleaning and lubrication is a routine thing
TacoCrawler is offline   Reply With Quote
Scx10 nube - Similar Threads
ima nube with a axial wraith... any tips? wraithscailer Axial Wraith 3 10-26-2012 08:54 AM
Can someone please help me? I'm a nube. peck126 Newbie General 66 03-10-2012 05:28 AM
General gear tooth machining question...from a nube... ChattyMatty Newbie General 2 01-11-2010 06:51 AM
toob nube (or - I'm in over my head now!!) Big Mike Axial SCX-10 59 10-17-2009 08:23 AM
help for a nube!!! RickSDMF Tamiya Txt-1 and Juggernaut 7 05-26-2006 08:15 AM
