01-02-2014, 09:33 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Walters, OK
| HH electronics simultaneously failing...... need help!
So I was driving my scx10 a short time after putting it together I was driving in the snow, but my BRXL is water proof. First my torque master 35T burns up, upon inspection, I discovered the winding had come unwound, locking up the motor and sending up a fury of smoke. I do not have pictures because I sent it off almost 2 weeks ago and have received no word on its condition. I replaced the motor with a HH 27T Eco motor, not sure on its exact name, which burned up soon afterwards. This time my esc has quit working and shows no signs of power. Even though it sat in the package for almost 2 months Before being opened, (my dad ordered early to get it while in stock before Christmas) And having little over an hour of runtime on it, it burns up? Wtf ? I am running 4s, but it is supposedly rated for 6s. With no single 540 limit. I was only running one motor. It is out of warranty. I don't know wtf I'm supposed to do with it now other than wonder why it happened? Sent from my iPod touch using Tapatalk |
01-02-2014, 09:47 PM | #2 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
| Re: HH electronics simultaneously failing...... need help!
4s eh? Were you geared down pretty good? What is your gearing?
01-02-2014, 09:55 PM | #4 |
5.8 Seems like a pretty good ratio to me. Have you contacted Holmes through his website? His stuff is quality and he takes care of people. I had several of his BRXL's completely submerged many times without issue. Keep in mind that even though brushed motors can be run in water and muck, it does accelerate their demise unless religiously maintained. |
01-02-2014, 10:12 PM | #5 |
I have contacted him but between Christmas and New Years I have not received a reply, I have had several motors of all brands burn up on 3 and 4 cells, the HH has held up the best. I was just concerned about the esc because I have never had anything like this happen before, and it is more expensive than the motor and cannot be rebuilt. I am by no means disappointed. I understand that 4s is a lot for these things to handle, But as I mentioned have never seen this before. Sent from my iPod touch using [ URL=http://tapatalk.com/m?id=1]Tapatalk[/URL] Last edited by Pgambardella; 01-02-2014 at 10:15 PM. |
01-02-2014, 10:20 PM | #6 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Sounds like you have something dragging in the drive train.. Axles that have a bad bearing, drive shaft that is binding... Something like that.. Just out of curiosity do you have OD/UD gears in the axles? I toasted a motor because the drivetrain was constantly binding, because of the OD/UD gears. I switched to UD/UD and the problem went away, immediately.. |
01-03-2014, 06:12 AM | #7 | |
| Re: HH electronics simultaneously failing...... need help! Quote:
01-03-2014, 06:48 AM | #8 |
My guess is that driving through snow with a 27t on 4s that you literally won't be able to gear it low enough not to smoke the motor. You probably killed the brxl with a dead short in the motor. I love brushed motors but my snow rig runs brushless.
01-03-2014, 07:40 AM | #9 |
Thanks for the input guys, my final assumption is that hot ridding around in the snow on a 4s is what killed it. By the way I still have the stock differential gearing, whatever it may be. Sent from my iPod touch using Tapatalk |
01-03-2014, 07:50 AM | #10 |
Pebble Pounder Join Date: Nov 2011 Location: Kittanning
i have a HH torquemaster here that im not useing.. Do u want it? to get ya back out on the trail?
01-03-2014, 08:25 AM | #12 |
13t Motor.. i dont have a esc. PM me for price |
01-03-2014, 08:09 PM | #13 |
| Re: HH electronics simultaneously failing...... Starting to get ridiculous...
My dad dug out another BRXL from his tool box today, it only had reverse after I plugged it into my rig, after leaving the 4s plugged in for a time, the biggest plume of smoke I have ever seen came out of it. I am begging to wonder what I'm doing wrong, it is odbviousley not a coinsidence. Has anybody else ever questioned the quality of these things? If so than I am no longer a customer of Holmes'.
01-03-2014, 08:25 PM | #14 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I think the 4s if asking a little much out of a brushed motor. I will say I ran 4s through Tekin Esc's on my Brood motors for years without any motor issues ( and by no issues I mean NO issues, never cleaned, turned a comm or even replaced a brush, I would say I am the exception not the rule, however) . But if your looking for the kind of speed a 27t motor gives you on 4s your best bet might be brushless. Are you running a BEC? If not I honestly would lay most to all of the blame on that for the ESC's burning up. All though I heard HH had some issues with keeping the magic smoke in some of his newest esc's for a bit. Heard it could be fixed with a firmware upgrade or breaking a trace on one of the boards, but I am not sure it is applicable to your esc's that burned up or even if it was truly a problem. HH should get back to you, but with the holidays I would give it a little extra time. |
01-03-2014, 08:27 PM | #15 | |
| Re: HH electronics simultaneously failing...... Starting to get ridiculous... Quote:
Did you happen to wire the battery backwards? | |
01-03-2014, 09:17 PM | #16 | |
RCC Addict Join Date: Oct 2011 Location: British Columbia
There has to be something else at issue here. | |
01-03-2014, 09:22 PM | #17 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
You really should post some pics of your wiring setup... so we can at least rule out the obvious things
01-03-2014, 09:45 PM | #18 | |
01-03-2014, 10:18 PM | #19 |
| Re: HH electronics simultaneously failing...... Starting to get ridiculous... |
HH electronics simultaneously failing...... need help! - Similar Threads | ||||
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
how often are your pc's failing/running poorly? | thecrusader | Chit Chat | 25 | 11-11-2009 12:18 AM |
Damn Lockers Keep Failing! Vendors Please Make Steel Ones! | kawika | Axial AX-10 Scorpion | 20 | 01-27-2008 08:18 PM |
