01-04-2014, 06:38 PM | #1 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| tekin hd motor?
Has anyone used the heavy duty tekin motors? Im looking to buy a new fxr for a build and wanted some info on how well they are built and likes and dislikes. Thanks
01-05-2014, 03:58 AM | #2 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
| Re: tekin hd motor?
They run great in Short course trucks which they where designed for. They will tear apart most crawlers or scalers. Tekin recommends using them with the RX8 if I remember correctly. If your build has a bullet proof drivetrain it should be all good. Good luck!
01-05-2014, 08:54 AM | #3 |
| Re: tekin hd motor?
Umm well im going to put it in a tf2. Hope I dont blow anything up. Lol I ordered all the upgrades I could afford to be installed as I build it. Thanks I dont know if it helps but I ordered the tekin fxr and brushed 35t hd combo. Last edited by buggynutt; 01-05-2014 at 08:56 AM. Reason: info |
01-05-2014, 08:56 AM | #4 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: tekin hd motor?
I run a 35T HD in a 9lb scale truck. It doesnt get hot or struggle even on steep climbs compared to the cheap RC4WD 35T which burnt out. a lot smoother as well. Just get the gearing right. I run a bit slow, but like driving up steep trails, so it keeps the stress off the motor. |
01-05-2014, 11:01 AM | #5 | |
| Re: tekin hd motor? Quote:
Another ? Lol it never ends. Has anyone used corosion x as a lubricant? Say for bearings and such. I see it used for waterproofing but not for the lubricating properties they say it has. Thanks | |
01-05-2014, 11:31 AM | #6 |
Rock Stacker Join Date: Jan 2007 Location: Carson City
| Re: tekin hd motor?
I'm running the Tekin 45T HD motor with the FXR esc in a Wraith, 7.4 2s lipo, Castle BEC, Solar 772 servo. Runs great, I also running 32pitch 56tooth spur and 10tooth pinion. I lost a lot of top end speed, but it crawls & trail runs great. |
01-05-2014, 02:00 PM | #7 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
01-05-2014, 04:28 PM | #8 |
| Re: tekin hd motor?
So the lubricating properties is not good enough for the bearings. Would you suggest removing the brushs before I soak it down? Thanks for the help all.
01-05-2014, 10:21 PM | #9 |
| Re: tekin hd motor?
I'm sorry. I thought you were talking about the pro4 HD. My bad!
01-06-2014, 03:28 AM | #10 |
| Re: tekin hd motor? No you don't have to. Just spray and let it air dry first. You could use any bearing oil or if you have any automatic transmission fluid around you can use that.
01-06-2014, 08:30 AM | #11 |
| Re: tekin hd motor? |
01-06-2014, 08:36 AM | #12 |
| Re: tekin hd motor?
Thanks for the motor info also. I have seen most people dunk there stuff in the corrosion x. Is this the best way to do the motor as well? Thanks
tekin hd motor? - Similar Threads | ||||
Tekin tekin 35t hand wound motor | vegas1973 | Electronics | 2 | 08-17-2012 10:22 AM |
