01-09-2014, 04:23 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Doylestown
| HITEC Servo ???? help!
I just got a hitec 7954SH and it came with a blue aluminum servo horn. The bag states they work with servos with a "+" stamped on the servo output shaft. The 7954 doesn't have that +. I called hitec and the guy said to ignore that as the were for older hitecs and to simply put the horn on and screw it down tight to set it. Is that right?? Just wanted to see if anyone can give some advice. Thx |
01-09-2014, 04:31 PM | #2 |
Quarry Creeper Join Date: Nov 2013 Location: Erie
| Re: HITEC Servo ???? help!
As long it has a 24t spline count it will work with your hitech servo. From what I have read the blue ones that come with the servo stink, but better than plastic
01-09-2014, 04:39 PM | #3 |
Ok the servo came with the horn so assume its 24 just really snug. Can't get it to set by hand and want to check before I screw it down. I'd hate toruin the servo
01-09-2014, 06:08 PM | #4 |
Rock Crawler Join Date: Mar 2011 Location: USA
Yes it's the same ,,When new they are tight fit,,, |
01-09-2014, 08:41 PM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
| Re: HITEC Servo ???? help! You'll never ruin a servo putting a horn on dude. Either it'll fit, or it'll be to loose. And your servo won't care either way. Now horns, are a different story. |
01-09-2014, 08:45 PM | #6 |
Thank you all for the help...I lined it up, screwed it down, and it fits like a glove!
01-10-2014, 07:06 AM | #7 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Re: HITEC Servo ???? help! The blue one that came with my 7954 has been through 3 G6s and many hours on the trail. I do have CMS so it is up out of the way, but they work just fine.
01-10-2014, 08:30 PM | #8 |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
Like said before, the blues work just fine. Yes, they are tight when new, don't worry. As for durability, the only issue you will have is that if it takes a hit while driving, it'll probably bend in towards the axle. The worst I have done to one was twist it up with a hs-7980 TH running 8.4v...it doesn't like that much torque...
HITEC Servo ???? help! - Similar Threads | ||||
Hitec APP-21 servo tester work with Hobbico CS170 servo? | neuro242 | Electronics | 11 | 09-24-2009 12:47 PM |
Hitec servo, RCBROS derlin links and servo plate | Lousyhero18 | Losi Mini-Rock Crawler | 2 | 06-28-2009 11:53 AM |
HiTec HS645MG Servo & 3Racing MRC2408 Servo Mount | stomper4x4.com | Losi Mini-Rock Crawler | 1 | 05-10-2009 06:33 PM |
Hitec Servo Voltage Ratings.......the answers from Hitec | roktoy | Electronics | 12 | 08-25-2008 06:07 PM |
