01-11-2014, 07:13 PM | #1 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Can some please tell me
I have Three Novak Esc's, a Micro Pro, and two Timbuk2's esc's and there is a slot for the fan to attach to with screws, and when I bought the Novak replace fans, didn't come with the screws, can some one please tell me, what size of thread do you need, its not metric, 3mm is too big, 2.5mm, is too small, could they be 4-40, cause 6/32, 8/32 is too big. are they 4-40 ?????
01-11-2014, 07:51 PM | #2 |
Newbie Join Date: Jan 2014 Location: USA
| Re: Can some please tell me
Just put a bit of glue on all ends of the fan then stick it on and let it dry...use super glue or shoogoo
01-11-2014, 08:14 PM | #3 |
nope want to be able to remove and clean the fan and heat shield periodically, too keep it running cool, and need the right screws.
01-12-2014, 09:22 AM | #4 |
Rock Crawler Join Date: Oct 2012 Location: Casper
M2.5x.45 uses a .0807" drill M3x.5 uses a .0984" 4-40 uses a .089" 4-48 uses a .0935" 4-48 isn't very common though so I would say it takes 4-40. Last edited by KJ10; 01-12-2014 at 09:26 AM. |
01-12-2014, 10:27 AM | #5 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Can some please tell me Quote:
01-12-2014, 11:55 AM | #6 |
the 2.5mm screws I got are fine thread, I use them to mount my RC4WD Proten rims, there garbage, use them for about two rims and they strip out or don't thread, I'm going my local Ace Hardware, they got a huge selection of metric and the standard, they got bolts, nuts, screws, washers, fasteners, over a hundred different springs, Ace is the place for me. better than Lowes and Home Depot, and got a way better selection. . |
01-12-2014, 06:16 PM | #7 |
I went to Ace hardware they are 4-40, thanks every one for the input.
