01-13-2014, 03:35 PM | #1 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Queston on brushless capacitors
I've been looking around here for a few day and can't seem to find my answer. I have a losi xcelorin sensored brushless system and when its all hooked up and you give it throttle the motor starts off nice and slow then it may jump around or rev up , then if you give it more throttle the rpm goes up smooth a little then rev's higher or lower without moving the trigger.I replaced the sensor wire with a new one already. Could a bad capacitor do this , the one thats on here looks fairly big. I'm new to brushless and don't know where to go from here. I also change the motor and the second one does the same thing. Any help would be greatly appreciated. Thanks
01-13-2014, 03:49 PM | #2 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: Queston on brushless capacitors
Do you have another esc to try? If so, try it and see if it does the same thing.
01-13-2014, 04:39 PM | #3 |
| Re: Queston on brushless capacitors |
01-13-2014, 07:21 PM | #4 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
It sounds to me like the speed controller has some current limiting going on.. Castle calls it punch control.. Current limiting cuts back the start up power to the motor, so you don't destroy lower C-rating batteries and make a bunch of heat in the motor. Short course guys use it a little like traction control.. |
01-13-2014, 07:50 PM | #5 |
Well i have the disc program that i loaded on my laptop , It works almost like a castle link, You hook a usb cable up to it.Theirs a bunch of stuff on it so i'll take another look.
01-14-2014, 03:02 PM | #6 |
I guess i stumped everybody with this question. |
01-14-2014, 10:55 PM | #7 |
Is the servo/esc wires bunched up with the motor and or battery wires?
01-15-2014, 04:11 AM | #8 |
No , I have everything separated , I recalibrated the esc and still the same thats why i was wondering how a bad capacitor would act. Its acts like i gets power spikes as it runs.
01-15-2014, 01:54 PM | #9 |
Rock Stacker Join Date: Nov 2013 Location: San Diego
Are you sure your sensor wire is good and plugged in correctly my ballistic 550 and mmp combo did the same thing turned out my sensor wire broke in the middle when I replaced it and checked to make sure it's good it worked great
01-15-2014, 04:34 PM | #10 |
Well i bought a new one and the second new motor i got had one come with it. The way the plugs made it looks like it only go's in one way. Is there a way to test or eliminate the capacitor to check a see if thats it?
01-17-2014, 02:55 PM | #11 |
Does anybody know if i could just remove the capacitor for testing purpose only . If so what would i do with the wires it connected to.
01-18-2014, 06:38 AM | #12 |
I'm sure somebody knows this.
01-18-2014, 06:41 AM | #13 |
Quarry Creeper Join Date: Apr 2013 Location: perkasie
I wouldn't remove anything yet it sounds like the esc Hass gone goody....i would set everything back to factory and start from there...or try another esc Sent from a big fat phone |
01-18-2014, 07:02 AM | #14 |
| Re: Queston on brushless capacitors Ya i already reset it to factory. I'll have to wait till i can get another esc. But like i said i dont think both motors and bad , The Ballistic crawler 18.5 is new with a new sensor wire.
01-20-2014, 03:53 PM | #15 |
Well i guess i'll try and unsolder the cap and see what happens. lol
01-20-2014, 05:01 PM | #16 |
Releasing the gods of white smoke.. Good luck getting the smoke back in... I am certain what you are seeing isn't from the capacitor.. It sounds like punch control or current limiting... Limits start up amperage to prevent from puffing battery packs... |
01-21-2014, 03:31 AM | #17 |
| Re: Queston on brushless capacitors Well no magic smoke but it made the motor turn very slowly. I hooked it back up and tried for the last time to reset the esc and it still the same. I got a novak esc on the way from a friend of mine. Thanks for all your help. |
01-21-2014, 09:13 AM | #18 |
Quarry Creeper Join Date: Jun 2012 Location: Port Coquitlam, BC
Does the esc support non sensored mode? If so, Try it without the sensor wire. This will help you isolate if it is a sensor board issue.
Queston on brushless capacitors - Similar Threads | ||||
Chassis Queston | Pyrodon | Losi Mini-Rock Crawler | 3 | 05-24-2012 08:13 PM |
queston | slowride1 | Axial XR10 | 3 | 08-10-2011 01:03 PM |
Queston to the Brushless gearheads | 92LILREDYJ | Electronics | 3 | 07-15-2011 01:38 PM |
chassis queston | rckid14 | Team Losi Comp Crawler | 2 | 09-28-2009 02:05 PM |
Queston about a XL-5 | John Deere | Tamiya Clod Buster | 6 | 03-01-2007 07:53 PM |
