Thread: question on esc burst draw vs motor peak current
Old 01-13-2014, 10:36 PM   #1
idk
Default question on esc burst draw vs motor peak current
are these the same numbers? if im choosing a esc that is 80 amp's
Continuous Current: 80A
Burst Current: 450A
the motor is
Continuous Current: 70A
Peak Current: 120A
i sure this is noob question but just wanna be sure before i order anything
thanks
its a 1/8 motor too is that makes any difference gonna be running 3s in a tmaxx
idk is offline   Reply With Quote
Old 01-13-2014, 10:41 PM   #2
Default Re: question on esc burst draw vs motor peak current
That isn't very much current draw for an 1/8 scale motor. What motor?
To answer your question yes those numbers are compatible.
Calderwood is offline   Reply With Quote
Old 01-13-2014, 10:42 PM   #3
Yup just as you are thinking. Your good to go with that combo.
Sam.... Always smoking the competition...
Joshs4x4toyz is offline   Reply With Quote
Old 01-13-2014, 10:51 PM   #4
idk
Turnigy 1/8th Scale 4 Pole Brushless Motor - 1900KV (USA Warehouse)
this is the motor i was lookin at i have 17.5 sensored 2200kv motor now but think it will be to weak from what i have read
Old 01-13-2014, 10:52 PM   #5
idk
thanks man
Old 01-13-2014, 10:55 PM   #6
3s is probably going to be pretty tame, just so you know.
Old 01-13-2014, 10:59 PM   #7
idk
ya thats what im gathering from my research but by tame do you mean slow top end? or less torque. this will be run is alot of tight jumpy area small skateparks backyard basher course.
Old 01-13-2014, 11:14 PM   #8
On 3s its not going to be spectacular in any department. If you ran two of your 3s packs in series that same motor would motivate that emaxx real well.
Old 01-13-2014, 11:17 PM   #9
idk
ill keep that in mind thanks and what about sensored in the maxx? worth the extra coin my esc does both
Old 01-14-2014, 12:02 AM   #10
Bashing, it will make very little difference.
Old 01-14-2014, 12:03 AM   #11
idk
awesome info thanks again
question on esc burst draw vs motor peak current - Similar Threads
Tested: Savox 1258TG current draw Evil Genius jr. Electronics 0 08-08-2012 06:06 AM
rated/peak current question! 73formulabird Electronics 8 01-26-2010 12:08 PM
current draw with external BEC but Tx off? mrklaw Electronics 14 08-07-2009 11:23 AM
Wheely King current draw? NickRummy Electronics 5 02-19-2007 06:59 AM
Servo current draw newth Electronics 17 11-30-2005 12:56 PM
