01-15-2014, 07:50 PM | #1 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
| is 20c enough?
Are 20C 3s lipo's enough for a tekin roc412 2300kv and mmp combo? It's going in my bouncer so it will be getting hammered on and I don't want to tax the batteries to hard.
01-15-2014, 08:26 PM | #2 |
| Re: is 20c enough?
Depends on the capacity. For instance a 5000mah20c pack would give you 100amps to play with whereas an 800mah20c gives you 16amps. The roc motors aren't quite as amp hungry as the pro4's, or so I hear. But it'll need more than 16amp |
01-15-2014, 08:33 PM | #3 |
Newbie Join Date: Jul 2012 Location: Oneida, NY
| Re: is 20c enough?
I've never managed to hurt a cheap 5000 mah 20c lipo in any of my crawlers weather they are heavy or sporty. I agree with Meatwad.
01-15-2014, 08:34 PM | #4 | |
| Re: is 20c enough? Quote:
I will add that 20c batteries can usually only be charged at 1c. I charge my 45c and 65c packs at up to 5c. So that's another factor to consider. | |
01-15-2014, 08:44 PM | #5 |
| Re: is 20c enough?
They are 2100mah 20c 3s batteries
01-15-2014, 08:45 PM | #6 | |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
I just recently switched from 30C to 45C (same mah and cells) and BOY can I tell a difference. There is so much more punch, and seems to have smoother low speed resolution. It just felt like it came alive, almost like I had put in a 4s rather than my normal 3s. There will be others that can give you a more technical answer with lots of numbers, but I always live by the more Cs the better (of course, with in reason). | |
01-15-2014, 08:46 PM | #7 |
| Re: is 20c enough? |
01-15-2014, 08:49 PM | #8 |
| Re: is 20c enough?
Also this motor and esc combo is mated to a two speed trans and is in a heavy rig, it's a wraith chassis made out of solid 3/16 steel rod, aluminum skid, and Currie wraith axles front and rear so she's not light by any means.
01-15-2014, 08:52 PM | #9 | |
Btw you will probably puff a 2100mah 20c with the roc. | |
01-15-2014, 09:01 PM | #10 |
| Re: is 20c enough? Agreed, a 2100mah20c pack would probably not like the roc so much. If you (the op) has the space, a parallel connector with 2 packs may be able to provide enough amperage. I had to do the same with my mmp/pro4 setup and a pair of 3s2200mah35c packs, just to be safe.
01-15-2014, 09:07 PM | #11 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: is 20c enough?
I puffed 2 Gens Ace Eco 1300mah 20C 3S batteries with a 35T/MMP in my old Tundra Truggy! So, yes you'll want to bump up the C rating to 40 or higher.
01-15-2014, 09:13 PM | #12 |
| Re: is 20c enough?
Right on thanks guy, I appreciate the advice, I had a feeling they would be pushed to hard.
01-15-2014, 09:16 PM | #13 |
| Re: is 20c enough? Quick second question for you, is there a formula that you use to figure out these figures? I have a sneaking suspicion I'm charging my 5300mah 70c 2s at to high of a rate.
01-15-2014, 09:29 PM | #14 | |
The C after the number is current. So a 5300mah 70c would work out like this: 5.3Ah X 70c = 371 amps Regarding charging, 5.3Ah X 1c would equal a charge rate of 5.3 amps. 5.3 X 5c would be a charge rate of 26.5 amps. Your battery manufacture will tell you what rate the battery can be charged at. | |
01-15-2014, 09:35 PM | #15 |
| Re: is 20c enough?
Any suggestions for a battery ratings for this combo? I am limited on space. I have two places I can mount it; In this spot I have 140mm long x 66mm wide x just about any height or thickness This one I have 138mm x 65mm wide x 34mm high/thick |
01-15-2014, 09:37 PM | #16 | |
01-16-2014, 09:27 AM | #17 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
| Re: is 20c enough?
If its going in a rock bouncer, I would put at least a 40c in it, as the motor and esc will be pulling a lot more current from the battery than a brushed system. The 20c will get very warm under a lot of load and will decrease the battery life. I run a 40c 3s and a 25c 3s in my wraith on a 17.5 and it does pretty god at a G6. The 40c never gets warm even under hard loads and the 25c gets pretty warm. So yeah I would recommend at least a 40c for ya bud. Hope this helped! |
01-16-2014, 09:32 AM | #18 | |
A 5000mah 20c can produce more current than a 2000mah 40c. | |
01-16-2014, 09:35 AM | #19 |
| Re: is 20c enough? Whoops forgot to mention that haha. I use 5000 mah in my rigs. Works pretty good. The 25c I use more for crawling, while I use the 40c for Ultra4 style driving. So a 5000 40c should work just fine. High ish amp output and lasts pretty long. It's a Sky Lipo, which are hard to get now. I don't know the exact amp output of batteries yet, but I should read up on it haha. |
01-16-2014, 12:12 PM | #20 |
Rock Stacker Join Date: Jan 2014 Location: Duluth, MN
| Re: is 20c enough?
This has been confusing the crap out of me, what is the difference of 20c, 30c, 40c, etc? Can't find a breakdown anywhere
is 20c enough? - Similar Threads | ||||
Is a 20c ok for moa | Constant Threat | Electronics | 10 | 01-12-2013 10:52 PM |
3s 11.1 20c 2200 | Jstalker | Electronics | 6 | 01-07-2011 07:47 PM |
20c or 30c | keithgemmill | Newbie General | 4 | 08-28-2010 10:53 AM |
20c or 30c | ckscaler | Electronics | 11 | 08-03-2010 02:28 PM |
Is 20c enough ? | Chooby | Axial AX-10 Scorpion | 8 | 04-05-2010 10:41 PM |
