01-18-2014, 08:25 PM | #1 |
Pebble Pounder Join Date: Feb 2013 Location: Fresno
| Savox SB 2230SG HV MS servo Unboxing and Review
I made the purchase for one Savox 2230 servo the other day, MAP 159.99 and I picked it up for 115.99 from my local shop. I am reserving a spot here for the unboxing and talking about its fitment compared to similar shorter servos. This will be going in my SCX10 with BMRC CMS/Panhard kit, basically this truck has been overheating and degrading cheap servos with 200 oz/in because of the wheel weight in my 1.9's and I also run 2.2's on it. Specs for the Savox SB2230 SG High Voltage Torque Monster: Right off the savox website Dimensions(mm): 40.3x20.2x45.0 Weight(g): 84.0 Speed(@6.0V sec/60): .16 Torque(@6.0V oz-in): 499.9 Speed(@7.4V sec/60): .13 Torque(@7.4V oz-in): 583.3 Gear: Unique Steel Bearing: 2BB Case: Full Aluminum 25 Tooth Spline Frequency: 250-333 Pulse Rate Frequency: 1520 Savox SB 2230SG High Voltage High Torque Standard servo Unb - YouTube Last edited by BuhBoombuh; 01-22-2014 at 08:12 PM. |
01-21-2014, 04:28 PM | #2 |
| Re: Savox SB 2230SG HV Monster Torque Standard servo |
01-21-2014, 06:39 PM | #3 |
01-22-2014, 11:11 PM | #4 |
Any thought about the servo guys? Would you like to see anything specific about it? a test or video? I am taking her for a test run tomorrow with the 1.9's and 2.2's on her, I will be reporting back on any heat ups, or troubles and the pros about this beast of a servo. Thanks for looking and don't forget to post a quick message with your thoughts. |
01-22-2014, 11:57 PM | #5 |
Pebble Pounder Join Date: Mar 2013 Location: Lehi
subscribed. Looking forward to how it tests out. I'm looking for the servo that will eventually replace my budget HiTec.
05-21-2014, 01:14 PM | #6 |
I forgot I had made this thread for the savox 2230, guess it's time for an update being just over 4 months in time and probably 100hrs of runtime on the servo. I honesty cannot complain a single bit - I am very pleased with this servo it has gobs and gobs of torque and it stays very cool for having to throw around a 7.5lb CMS design scx10. 2.2s and 1.9s never saw a 100 degree F case temperature even on the really jagged lake rocks we often run on. Still a draw back is but usually not an issue for us upgrade types is the needed external BEC and rx Cap to keep the servo from eating your ESC's BEC alive. I will for sure buy another SB 2230SG when my 2.2 truck is ready for it, just outstanding how powerful and spot on this servo is. 8/10 if I had to rate it, size can be an issue for some and the 6" servo wire is just not enough for reaching the rx. ITS AN AIRPLANE SERVO!! Last edited by BuhBoombuh; 05-21-2014 at 01:23 PM. |
06-02-2014, 10:40 PM | #7 |
Newbie Join Date: Aug 2005 Location: Douglas, WY
I have been thinking on snagging this servo. Some folks don't care for savox. I need something stronger to than the Solar D772's gear set which keep failing on me.
06-02-2014, 11:17 PM | #8 |
RCC Addict Join Date: Oct 2012 Location: Norcal
Savox SA-1230, 500oz of torque for $75.00...
06-03-2014, 12:46 AM | #9 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
I got the SA-1231 for my crawler.. little less torque at 444oz, but a little more speed than the 1230. Which seem to be the same servo, just different gear train, speed vs torque. Not tried yet! |
Savox SB 2230SG HV Monster Torque Standard servo - Similar Threads | ||||
Best high torque standard soze servo above 300 in oz? | rockwerks | Electronics | 9 | 01-14-2007 07:17 PM |
