01-23-2014, 06:05 PM | #1 |
Newbie Join Date: Jan 2014 Location: Silver Creek
| motor voltage limits?
I want to know if there's a limit to the "volt up gear down" axiom? Specifically, I have a deadbolt that I got for xmas(would have been much better to get a kit as I have replaced all but the radio already). I got a HH BRXL 35t tqm sport combo and a HH 27t sealed can for mud play. Been running it on 2s but I want more. The brxl is rated for 6s. Will these motors be ok at that voltage? I was thinking of making an adapter to run 2 batteries in series. So 2 2s's would give me 4s or 2 3s's would be 6s. Is this all wrong? I don't want to ruin it with trial and error. Also thinking of a 13t pinion. Is that going to be low enough?
01-23-2014, 06:10 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: motor voltage limits?
I'm running a 35T on 4s. So far so good.
01-23-2014, 06:36 PM | #3 |
If you use more than 4S you will get a lot of brush wear and will have really short run times between brush changes. Check out the HH site's Holms tech under gearing. 540 Brushed Motor Care, Installation, and Troubleshoot | The Search for Power Here is the quick summary version: Use 11.1v to 14.4v lipo whenever possible. With the speeds that you want, you would probably be better off going with a brushless system. |
01-23-2014, 08:02 PM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
I run my Novak 45t and 35t on 4s regularly and they hold up fine. The HH motors are supposed to be better motors so I would say you are good to go.
01-24-2014, 02:19 PM | #5 |
Thanks. I didn't see that when I looked at hh tech. I'm just on my phone so... What about doing a series harness for 2s to 4s? Any problem with having the extra connector in the mix? Or I could just get a 4s |
01-24-2014, 02:40 PM | #6 |
| Re: motor voltage limits? |
motor voltage limits? - Similar Threads | ||||
ESC Limits vs Motor... question... | Cake Eater | Electronics | 5 | 03-13-2015 01:28 AM |
Castle Creations SV3 brushed motor limits? | jeep95 | Electronics | 3 | 11-09-2013 04:07 PM |
Factory ESC/RX current and motor limits? | 89redranger | Losi Micro-Rock Crawler | 7 | 12-29-2012 11:33 AM |
Tekin FX-R Motor Limits??? | biggin69 | Newbie General | 1 | 09-21-2010 02:21 PM |
lathe motor/any 540 motor voltage handling?!? | spike | Electronics | 0 | 03-03-2005 07:30 PM |
