01-23-2014, 07:53 PM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: Roanoke, VA
| Extending ESC Wires
I'm working on my Wraith and I'd like to install the ESC in the rear. I'd also like the plug for the battery to be under the hood. So can I lengthen my ESC Battery wires without any ill effects? Just guessing they would be 8-10" long. I'm be running 2s / 3s to a Crawlmaster 13T. At the moment I will be using an AE2 ESC but will eventually switch to a BRXL. If I can extend them should I use couplers and heat shrink them or solder them together and heat shrink them or what? Open to suggestions here. |
01-24-2014, 12:08 AM | #2 |
| Re: Extending ESC Wires
Yes you can extend them. What method best to use depends on a couple of issues: - From an electrical point of view the very best would be to replace the current cables with longer ones. Resolder on the ESC board. Requires some soldering skills and proper equipment not to damage the ESC in the process. - Second best is to solder on extensions. That's fairly easy to do. - Using connectors in the middle is a good option if you want to mount and dismount the equipment quite often, and don't need maximum performance. |
01-24-2014, 07:23 AM | #3 |
Sounds good. I'll definitely solder the wires together, I won't have any need to remove them and I'm not comfortable enough with soldering on the ESC's board.
01-24-2014, 08:45 AM | #4 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Just use a good connector and lengthen them on the other side of it. For 2 wires I would use a deans, or a pair of 4mm bullets. Having that junction makes it much easier to work on later. And as long as it is a good connector you will have no issues, especially on a low powered crawler.
01-24-2014, 07:33 PM | #5 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I like to solder mine. I use wire that is at least the same diameter as the speed control wire, never smaller. Smaller wire and connectors=resistance=heat.
01-25-2014, 08:19 AM | #6 | |
| Re: Extending ESC Wires Quote:
I purchased 12awg silicone wire, coming from the ESC is 13awg so it should be fine. | |
01-25-2014, 08:45 AM | #7 | |
On a lower powered car like a crawler I would ( and do) use a connector to extend wires. It makes it easier to work on by just disconnecting the wires, vs. fighting with them in the way if you need to take things apart. On my short course truck I soldered the wires to extend them. Mostly because I did not have good 4mm bullets. BUT, on my SC truck everything is open, I can pull the motor and esc out as an assembly without issue. On my wraiths I use connectors. I also have just pulled the wires out of the board and used long wires. You really need to have a good soldering station and tin the hell out of the tip to break the factory solder loose. Not really a big deal. | |
Extending ESC Wires - Similar Threads | ||||
What the %$#!^@#, Just burnt up ESC wires | bsn | Electronics | 17 | 08-08-2013 06:49 AM |
Long/extending brushless ESC battery wires... | simon170 | Electronics | 5 | 02-16-2013 11:27 AM |
Extending leads on axial ESC | lurchy | Electronics | 1 | 01-02-2013 09:33 AM |
Extending battery wires | day215 | Electronics | 5 | 12-13-2010 05:55 PM |
Esc Wires | pureadrenalin | Electronics | 2 | 12-15-2006 08:31 AM |
