01-24-2014, 03:28 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Winston-Salem
| Crawler seems weak. Affeced by cold weather?
So I just got back in from playing with my fairly new Scx10 Rubicon. While out I noticed it seemed a bit weak and didn't have as much pep as it had a couple days ago, or even yesterday for that matter. I thought it might be the battery so I swapped in a newly charged one with no change in performance. I just recently waterproofed my crawler and have been in the water/mud for the past couple days without any issue other than the first day being out I got a smell of burning wire while crawling through a creek. No visible smoke and everything seemed ok. I think some sand had gotten into the motor and was causing some friction on it. Anyways, I was out today in the coldest weather I've had my crawler out (around 25*F) and it just seemed slow. I first noticed the issue while crawling over some rocks. Got out in an open area to confirm that it was acting very weak. Any suggestion as to what may be my problem? I'm still very new at this and learning so help would be appreciated |
01-24-2014, 05:42 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Crawler seems weak. Affeced by cold weather?
Did you spray out the motor with electronics cleaner and re-lube the bearings after running it in water or did you just put it away when you were done playing?
01-24-2014, 05:58 PM | #3 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
If you have a lot of grease packed in the tranny and the rears when it cold like that it really make the grease get pretty thick.
01-24-2014, 06:44 PM | #4 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
Low temps will affect lipo performance, see this post on HF Lipo Batteries & Cold weather - HeliFreak Seems serious, some are hitting the LVC. |
01-24-2014, 06:53 PM | #5 | ||
| Re: Crawler seems weak. Affeced by cold weather? Quote:
01-30-2014, 10:50 AM | #6 |
So my crawler is definitely weak and I don't think it's being caused the the cold weather. Any suggestion on where to go from here?
01-30-2014, 01:51 PM | #7 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
what is your current set up? how old?? battery, esc, motor, pinion. BEC or no BEC. define weak, to me parts get weak then break.
01-31-2014, 12:15 AM | #8 |
My "Competition Ready" crawler was also very weak out of box. Lots of unnecessary friction due to poor mounting in the factory, with most screws overtightened. Took me half a year and two burnt up motors to straighten it all out... |
01-31-2014, 07:09 AM | #9 | |
When I say weak I'm talking about the power. It used to have enough power to do donuts, flip itself over while turning etc. Now, it's a slow turd. | |
01-31-2014, 08:35 AM | #10 |
check your pinion and spurgear mesh...might be tightened....Olle P is correct, take it apart and check each screw....its good practice to do this, I tear mine down every 3-4 long runs.... 12-16 hours of run time..clean the motor, bearings....this is a working hobby..its really a good day when 3 of my rigs need torn down, I close the door to the shop, turn on U-tube, and rip into them...5-6 hours easy... if your mesh is ok, take your motor out..or move your pinion away from your spur..then turn each wheel..should spin freely, undo each drive line..turn the axles, should spin very free.... time to get to know your rig!! |
01-31-2014, 09:02 AM | #11 | |
01-31-2014, 12:51 PM | #12 |
If you need more help, PM me Ill send you pics of what I am talking about.
02-01-2014, 08:40 AM | #13 |
| Re: Crawler seems weak. Affeced by cold weather? |
02-06-2014, 05:41 PM | #14 | |
Squatch71, I tried to PM you. I got this message: Quote:
Crawler seems weak. Affeced by cold weather? - Similar Threads | ||||
Cold Weather and Lipos | Harvo | Electronics | 11 | 11-11-2011 12:45 PM |
Cold Weather Shop | neillarson | Chit Chat | 2 | 01-23-2011 06:15 PM |
Crawler InNovations(Nova's Ark)2 stage 2.2 foams Cold Weather Test!! | Jeepial | Tires and Wheels | 17 | 01-18-2010 07:08 AM |
Painting in Cold Weather | Jmterminator | Paint and Body | 22 | 12-07-2008 06:42 PM |
Oli wt. for cold weather | drumbeater | General Crawlers | 4 | 12-18-2007 02:48 PM |
