07-05-2016, 11:07 PM | #621 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: HH Servo
Ok so I reread the whole post and John says in post 442 the hv400 uses savox gears and unfortunately savox will not sell to him anymore. Sorry for the bad lead. 149 r/c worx team driver |
07-06-2016, 06:35 AM | #622 | ||
| Re: HH Servo Quote:
For folks who had precious little runtime before a hv400 failure, we are trading out hv500s to keep them running. May be out of warranty, but I understand that sometimes we buy stuff that sits on the shelf for a year or two before use. Truth be told, im still five figures in the red on servos as a whole. But that doesn't change our commitment to customers. | ||
07-06-2016, 06:41 AM | #623 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
| Re: HH Servo
I'm still not 100% clear, Please forgive me here.. So I have a batch one HV500.. <3 it.. You guys sent me a replacement set of HV500 gears, Does this set of gears have the updated pin included? Does my new SHV500 have the updated pin? |
07-06-2016, 07:35 AM | #624 | |
| Re: HH Servo Quote:
If you got your gearset recently, same time as SHV500 shipment came in, it has the properly hardened middle pin. If the gearset was from a month ago, it has a chance of having overhardened pins. We still aren't above a 5% break rate, to put some perspective on the overall issue. The SHV500 has the properly hardened pins, and so does all HV500 inventory currently on my site. Any "old order" inventory was taken apart and rebuilt. | |
07-06-2016, 08:41 AM | #625 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
| Re: HH Servo
Greetings, Thanks for the help guys! This servo was a replacement after going through 3 gearsets. It lasted the longest. It probably has 20 hrs on it. I wouldn't call it minimal use. Last time the truck was out was February. On a side note, it wasn't the usual bell looking gear I believe it lasted longer as I only ran it at 6 volts. Thanks, John |
07-15-2016, 01:53 PM | #626 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: HH Servo
What servo horn does everyone like to run? Yesterday I noticed the locknut on the backside of my racers edge horn is contacting the servo case on my scx10. I put this horn on because the axial horn that was on the scx went to my bomber build...
07-15-2016, 04:33 PM | #627 | |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| HH Servo Quote:
Try threading the screw from the other direction. Use the lock nut to secure the link to the screw on the bottom side of the servo horn. That way, the only thing between the servo horn and the servo case is the button head of the screw, which should clear without any problems. Also, it's a good idea to keep thin locknuts on hand for places where you don't have a lot of clearance. Sent from my iPhone using Tapatalk | |
07-15-2016, 04:43 PM | #628 |
| Re: HH Servo
Thanks N2R! That worked perfectly. Appreciate the help
07-19-2016, 02:09 PM | #629 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: HH Servo
Can we do the diode drop thing to run the SHV500 off of 4S, or won't diodes pass the current? What do these things draw anyway?
07-19-2016, 07:13 PM | #630 |
Quarry Creeper Join Date: Nov 2011 Location: In the woods
| Re: HH Servo
I have the HV500 on my bomber and it's just awesome. I have been replacing all my servos to HH brand servos. The idea you can message Holmes and he actually helps you is worth the money.
07-19-2016, 07:42 PM | #631 |
Quarry Creeper Join Date: Jun 2010 Location: Farmington
| Re: HH Servo |
07-19-2016, 08:35 PM | #632 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
| Re: HH Servo
I bought my HV5000 servo from Supershafty. How do I tell they have the upgraded pins?
07-19-2016, 09:43 PM | #633 | |
| Re: HH Servo Quote:
I won't be recommending any sort of modding for 4s running. I am working on the components needed to make future manufacturing tolerant of 4s. ff | |
07-19-2016, 09:49 PM | #634 |
| Re: HH Servo
So we can proactively order the upgraded pins? Will a paypal invoice from the vendor be good enough for proof of purchase?
07-19-2016, 10:01 PM | #635 |
| Re: HH Servo
yes, you can absolutely do that.
07-19-2016, 11:06 PM | #636 | |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: HH Servo Quote:
I'm emailing him again. Nothing showed in my mailbox. (Edit: within two hours of emailing again, I have a tracking number from Justin.) Last edited by gbean; 07-20-2016 at 12:10 PM. | |
07-20-2016, 10:41 AM | #637 |
| Re: HH Servo |
07-20-2016, 07:00 PM | #638 |
| Re: HH Servo
3 to 6 months. I actually did all the work for 4s use two months back, just waiting on samples.
07-21-2016, 09:16 PM | #639 |
Quarry Creeper Join Date: Dec 2013 Location: ][V][
| Re: HH Servo
I have a hv500 from the end of batch 1 ish? HH ran out of their first batch but supershafty had a few left so I grabbed it from them. Could this servo have a issue with the over hardened pin? Thanks.
07-22-2016, 05:00 AM | #640 | |
RCC Addict Join Date: May 2009 Location: Weston
| Re: HH Servo Quote:
Read post 636. All you have to do is look. Sent from my iPhone using Tapatalk | |
HH Servo - Similar Threads | ||||
C.I. - Servo Guard - Servo Clamp - Servo Mount - Annoucement | Nova's Ark | Crawler Innovations | 10 | 05-07-2015 01:25 PM |
***Crawler Innovations Engraved Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 106 | 10-20-2013 02:16 AM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 228 | 07-12-2011 01:17 PM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 266 | 04-01-2011 02:18 PM |
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! | Nova's Ark | General Crawlers | 219 | 10-18-2010 12:43 PM |
