01-27-2014, 01:25 PM | #1 |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
| Need some bec wiring and voltage advice please look and help me out
Here is a current diagram of the way my truck is going to be setup when my rear winch arrives PLEASE SEE BELOW PICTURE FOR WHAT I NEED ADVICE ON I am wondering if I need to upgrade to a bec pro to get full voltage to both my steering servo and winches. My current castle bec is set at 6.4V and is plugged into a y servo cable with my steering servo and goes into my rx. The new warn rc4wd winches use a different control unit then the older winches and do not have a seperate power supply. The new winch controller is powered from the rx. I have a heyok winch toggle switch coming so I can use one winch controller for 2 winches and just flip the switch to select front or rear. I am trying to decide if I should get a castle bec pro because they have 2 power outputs instead of one. So what I am thinking is that I could do something similar to what I have done with my current bec and use a y cable for ouput 1 and plugging it into the y cable and then the other plug is my steering servo then to the rx. Then output 2 of the bec again with a y connected to my winch control unit and then to the rx. I would just appreciate the help so I make sure to get enough voltage to everything since currently my winch servo is a little slow due to being powered through the receiver. My servo is a hitec 7954SH and my servo winch is a hitec 645mg with the circuit board and pot adjuster removed that is powered and controlled by a winch controller. Last edited by ssdub33; 01-27-2014 at 06:01 PM. |
Need some bec wiring and voltage advice please look and help me out - Similar Threads | ||||
I Need Some Wiring Advice... | Airmaxx23 | Electronics | 3 | 12-16-2010 02:10 PM |
Wiring HD A/V Advice | Robb | Chit Chat | 10 | 09-16-2008 09:42 PM |
wiring | corvette crawle | Electronics | 1 | 08-13-2008 03:16 PM |
Wiring??? | Wheels4186 | General Crawlers | 2 | 06-01-2007 02:59 PM |
Wiring Help! | Z71HULK | General Crawlers | 7 | 01-13-2007 10:33 AM |
