01-29-2014, 01:07 AM | #1 |
Newbie Join Date: Apr 2013 Location: Newport News
| Help!! Motor quits working while steering
I have a wraith and am running stock radio and receiver. I am using a Holmes Brxl with a trailmaster and a savox digital steering servo. Running 3s but it doesn't make a difference on the problem. I am having a problem with the motor stopping when I'm turning. I have tried recallibrating and tried a different servo. While holding throttle constant when I steer the light on the brxl changes from green to red and back green again once motor runs again
01-29-2014, 01:22 AM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Help!! Motor quits working while steering
I'm assuming that you're not using a separate bec?
01-29-2014, 01:32 AM | #3 |
No. And in all honesty don't know much about them
01-29-2014, 02:03 AM | #4 |
That Savox servo is more than likely over-amping the internal bec. Get yourself an external bec and that will cure your problem. Read this...Yes, you need an external BEC! |
01-29-2014, 02:10 AM | #5 |
The problem happens with any servo I have tried and will happen when no load is being applied like when I have truck on a stand so there is no resistance. Thanks for the info on the bec I will def check it out. I am changing out to a velineon motor and esc to see if that makes a difference now. I know that setup is horrible for a wraith but I have a ton of fresh snow and want to go play at all cost
01-29-2014, 02:30 AM | #6 |
Oh wow that's a new one to me! Maybe the esc is faulty? I have the brxl as well but haven't had one problem yet.
01-29-2014, 03:14 AM | #7 |
So I put the velineon system on and the problem went away
01-29-2014, 03:15 AM | #8 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
savox servos are POWER hogs and it may be stressing out the BR-XL
01-29-2014, 04:44 AM | #9 | |
| Re: Help!! Motor quits working while steering Quote:
01-29-2014, 06:20 AM | #10 |
I recently changed the battery connector on the esc I wonder if maybe I have a bad solder joint
01-29-2014, 11:34 AM | #11 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
Get an external bec & go from there. Your only asking for drama without one.
01-29-2014, 12:21 PM | #12 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
^this. what you're experiencing is called a "brown-out" when the draw from your servo is too much for the ESC to handle, thus it hesitates. eventually you'll need a BEC anyways depending on what battery setup you have, so might as well upgrade now (vs just running servo off battery - depends on what servo you have)
01-29-2014, 07:49 PM | #13 |
Thanks for all the input I guess I'm getting a bec. For now I'll run a different system until I get one wired in
01-30-2014, 11:54 PM | #14 |
I had the same issue with a brxl and savox servo. Got a bec and still the same issue, something just wasn't right. Got rid of the savox servo and got rid of the problem..
Help!! Motor quits working while steering - Similar Threads | ||||
need help!!! front steering on ax10 not working :( | jboehler04 | Electronics | 11 | 05-21-2013 05:23 PM |
TQ3 question, rear steering quite working | 70duncan | Electronics | 2 | 02-17-2009 07:12 AM |
working hydrolic steering! | Rider385 | General Crawlers | 36 | 02-08-2008 07:15 PM |
Steering not working properly?????? | exoyota | Electronics | 6 | 03-02-2007 09:31 AM |
EVX just quits | polyophio | Electronics | 4 | 04-16-2006 07:34 PM |
