02-03-2014, 04:19 PM | #1 |
Rock Crawler Join Date: Jun 2013 Location: Portugal
| Split 1 channel to 2 winches?
It's possible to have 2 winches for only one channel? like a switch to power the one I want to use?
02-03-2014, 04:34 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
| Re: Split 1 channel to 2 winches?
Yep, I have one channel running to a Heyok controller and then the output from that runs to a 3 position switch that I can select the front or rear winch from.
02-03-2014, 04:34 PM | #3 |
Quarry Creeper Join Date: Nov 2012 Location: Paxton
I think if you put a toggle switch on the signal wire between the 2, then splice the positives together and the negatives together it should work. but wait to see what others say.
02-03-2014, 04:37 PM | #4 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Yes Heyok built me one with a winch controller built in. Look in the venders electronics section under the servo toggle switch thread!
02-04-2014, 04:15 PM | #5 | |
| Re: Split 1 channel to 2 winches? Quote:
Servo Toggle Switch | |
02-05-2014, 03:32 PM | #6 |
That's it. Thanks !
02-05-2014, 04:03 PM | #7 |
A less expensive way to run two winches would be to feed one winch controller output into a switch so that it can feed either the front or the rear winch. Then only one winch controller is needed. |
02-06-2014, 10:05 AM | #8 | |
Split 1 channel to 2 winches? - Similar Threads | ||||
4PL with winches of channel 3 and 4 | reden | Electronics | 8 | 10-02-2014 10:41 PM |
How to run dual winches (front & rear) with a two channel radio. | Trump1 | Electronics | 15 | 04-09-2013 08:23 AM |
Feeler: Operate two winches from a Three Position Channel? | heyok | Electronics | 2 | 02-03-2011 03:05 PM |
Tech: Building a split 4 or split 3 2/3A battery pack | Grizzly4x4 | Electronics | 15 | 09-19-2007 08:37 PM |
dual winches on a 3-channel radio | chino63 | Electronics | 1 | 01-03-2007 11:32 AM |
