02-11-2014, 05:27 PM | #1 |
Newbie Join Date: Oct 2012 Location: Olathe, KS
| Twitchy servo.....YES I HAVE A BEC.
So I just installed a Hitec 7980th in my wraith along with a CC BEC which has not been flashed to run 7.4 volts yet. I have eliminated the red wire on the plug where the BEC plugs into. The ESC. The servo is super twitchy and I cant figure out why. Any input is appreciated!!
02-11-2014, 05:52 PM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Twitchy servo.....YES I HAVE A BEC.
Twitchy how? Is the servo twitching while sitting still or does it happen when you turn the wheels? The cc bec is set to 5.1v from the factory so your really not getting any benefit from the bec.
02-11-2014, 05:54 PM | #3 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
New servo? Try wiggling the wire at various points to see if it has an effect. I had a wire break and create the same issue.
02-11-2014, 06:38 PM | #4 | |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
| Re: Twitchy servo.....YES I HAVE A BEC. Quote:
02-11-2014, 09:49 PM | #5 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Was the 7980 used or new? They are programmable. I cannot remember the setting, but there is one you change that opens the resolution and makes it very sensitive to radio inputs. So a little movement from the radio makes a lot of movement on the servo. It makes the servo seem really jumpy, and that is with a high end radio. Add in a cheap radio and it could act weird. I also have had things act nuts with the esc interfering with the BEC. I had to change the firmware on the esc ( castle sidewinder, and MMP) Your wording is a little vague. You removed the red wire FROM the esc? Then just plugged the BEC into the reciever? If you removed the red wire from the BEC, your not getting any power from it. |
Twitchy servo.....YES I HAVE A BEC. - Similar Threads | ||||
Twitchy twitchy twitchy!! Help | rockwha? | Electronics | 11 | 04-17-2011 09:21 PM |
Twitchy ESC | rabfan | Newbie General | 0 | 02-15-2010 05:14 PM |
Twitchy twitchy, replaced everything... | bruteforce | Electronics | 21 | 10-20-2009 12:15 PM |
Twitchy 4ws w/ 2 5955s | Zero | Electronics | 5 | 09-03-2005 11:15 PM |
Rear Servo Twitchy? | DBrown2 | Electronics | 1 | 02-07-2005 03:04 PM |
