Thread: Drop-in gear for Hitec 645mg?
Old 02-12-2014, 07:59 PM   #1
Default Drop-in gear for Hitec 645mg?
I have now stripped the metal gear in the 645mg twice, both on bad falls/rolls. This is on a SCX10 that isn't heavily modified. Otherwise this servo works well for my needs.
Are there any other gears that I can replace this one with? Note this is not the aluminum gear nor the plastic or nylon one, but the metal one (unsure exactly what it's made of). I searched and couldn't find any results of people using another gear.
I don't want to keep buying spare gearsets as the next purchase will mean I've spent as much on spares as the original cost of the servo.
Cr00zah is offline   Reply With Quote
Old 02-13-2014, 04:15 PM   #2
In the band for now.
Default Re: Drop-in gear for Hitec 645mg?
the 645 just dosent have the power and your just going to keep stripping gears, and there are no other gears to replace except the ones that are in it. save up and get a better servo, beats replacing gears all the time.
15 bucks a pop for replacement gears add up quick
lemonhead is offline   Reply With Quote
Drop-in gear for Hitec 645mg? - Similar Threads
Hitec HS-645MG? mmatthews Losi Mini-Rock Crawler 6 07-31-2011 05:11 AM
hitec 645mg ixer Losi Mini-Rock Crawler 32 02-11-2010 09:13 PM
Hitec 645mg Jesse S Electronics 1 01-10-2007 05:30 PM
