Thread: Hitec HS7950TH arm screw
Old 02-16-2014, 07:33 AM   #1
Default Hitec HS7950TH arm screw
Can someone tell me what thread is used on this servo, to attach the servo arm? I have literally hundreds of screws in my box and the only one that fits this servo is the one in it now. Kind of feel like a dummass, but I'm tired of trying to figure it out.
U F'n A Racing is offline   Reply With Quote
Old 02-16-2014, 07:42 AM   #2
Default Re: Hitec HS7950TH arm screw
I believe they are 2.5mm.
Slowkrawl is offline   Reply With Quote
Old 02-16-2014, 08:24 AM   #3
7950 uses a 2.6mm screw
War Pig is offline   Reply With Quote
Old 02-16-2014, 10:19 AM   #4
M2.6x8mm for the stock length screw for Hitec. I use cap head screws instead of phillips head to make it easier to remove the screw when needed.
https://www.servocity.com/html/socke...ews__meta.html
k7zpj is offline   Reply With Quote
Old 02-16-2014, 10:59 AM   #5
Gotta love this forum! Does anyone know the thread pitch? Or, does 2.6mm only come in one thread pitch? It's just too easy for me to swing by Fictional on my way home from work.
Old 02-16-2014, 03:25 PM   #6
Looks like 2.6 is all .45 pitch, at least that is all you can get from Mc-Carr
bodhi is offline   Reply With Quote
Old 02-16-2014, 03:41 PM   #7
I love McMaster-Carr.
McMaster-Carr
LuckyDevil is offline   Reply With Quote
Old 02-16-2014, 03:51 PM   #8
Rpp sells them as well. They even make mention of them fitting HiTecs. I have bought these from them before. Good to have in the parts bin.
HPI Racing 2.6x6mm Cap Head Screw (12)
Szczerba is offline   Reply With Quote
Old 02-16-2014, 04:26 PM   #9
If you are in Reno. I would check with C.K.R.C.
yjbrad is offline   Reply With Quote
Old 02-16-2014, 06:04 PM   #10
Again, thank you all. Yjbrad, last time I went there they only had one phillips head screw and the dude didn't seem to really know what he was doing. Not sure how the place is now that Jake sold it........haven't been there yet.
Old 02-16-2014, 08:56 PM   #11
:shoc k:
Colgout is offline   Reply With Quote
Old 02-16-2014, 08:58 PM   #12
You should check them out. I heard things changed there.
Hitec HS7950TH arm screw - Similar Threads
Missing screw on shoulder arm (King Pins) ECAMERON87 Tamiya TLT Crawlers 3 05-11-2005 12:01 PM
stripped servo arm screw fix? rckjeep Electronics 6 08-27-2004 12:05 AM
