02-21-2014, 03:54 PM | #1 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Savox tooth count
I ordered a Savöx SA1231SG servo for steering duties on my wraith. How many teeth will it have on the output shaft? Can anyone recomend an aluminum servo arm? Double clamp or single clamp arm? Length? Thanks for your suggestions! |
02-21-2014, 04:07 PM | #2 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
It's 25 spline same as futaba Sent from my LG-E980 using Tapatalk |
02-21-2014, 05:20 PM | #3 |
Thank you!
02-22-2014, 10:20 PM | #4 |
Quarry Creeper Join Date: Jan 2007 Location: Las Cruces, New Mexico
| Re: Savox tooth count
I think what ever servo arm you go with will be fine. I used to run a cheaper hitec alu servo arm that didn't even clamp I a 2.2 comp rig for over a year and never stripped it. I even used to run the same servo and arm on a 1/8 buggy and truggy always at 6v putting out about 275 grams.
Savox tooth count - Similar Threads | ||||
tooth count on wraith trans-internals? | SwampDawg | Axial Wraith | 5 | 06-18-2013 01:06 AM |
low tooth count pinion | TRAV | Kyosho Crawlers | 5 | 10-31-2010 01:19 PM |
4th gear tooth count? | Aussie Nerd | EnRoute Berg | 0 | 11-30-2009 12:34 AM |
will a 17 tooth pinion fit a 93 tooth spur? | solomon7 | Newbie General | 4 | 08-09-2007 11:35 PM |
