03-06-2014, 08:22 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: brockville
| Resistance in 4 pole motors
I installed a hobbywing sensored 3400 kv motor and traxxas rebrand mmp in my scx10 figuring from what I read on here it should be quite smooth in the low end, it seems to almost chug at very low speed(not cogging,the sensors are working) It seems to have resistance when rolling it by hand is this normal? Gear 11/60 meshing seems fine |
03-06-2014, 08:26 PM | #2 |
Taking the motor out the truck rolls fine with little resistance, Also if anyone has any tips I find it hard to keep a smooth steady low throttle..been playing with the setting to no avail, maybe I'm expecting too much? Brushed 35t is a fair amount smoother low end |
03-06-2014, 09:01 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Sounds to me like some issue with the sensor cable or the wires are mixed up from motor to esc? Make sure you have no timing, and try smart mode that will automatically switch , but I would expect a relatively smooth start for you as well.
03-07-2014, 07:16 AM | #4 |
I've done everything you have posted thus far, I'm wondering if I'm just expecting brushed start up out of it, on flat I can smooth start but putting it into any bind it's hard to smoothly start out of it...the little extra throttle needed to finish the crawl over causes it to pop instead, I will keep playing with the esc settings and post my findings
03-07-2014, 07:18 AM | #5 |
Settings: Fwd pow- 70 Rev- 50 Punch control- 50 Start pow-med Smart sense mode zero timing |
03-12-2014, 03:58 AM | #6 | |
| Re: Resistance in 4 pole motors Quote:
My solution has been to use a smaller pinion, reducing the torque required at crawl speed (and also, unwanted, reducing the top speed). | |
03-12-2014, 10:51 AM | #7 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
You have gone from a 35T (±1600kv) motor to a 3400Kv sensored. Since you have nearly twice the speed, the start-up speed of the 3400kv will be harder to maintain it's smoothness. I've gone from a 35T (1500kv) to a 21.5T (1800kv) sensored setup, and I have incredible low end resolution! |
03-13-2014, 04:47 PM | #8 |
I've put the t35 back in, decided the brushless setup is just not what I'm looking for in an scx10 I'm thinking an ifs ultra 4 type would be perfect for the brushless setup! Now I'm just missing the extra money to do this lol
03-13-2014, 05:03 PM | #9 |
I use the same 3656sd in my wraith. I starts up plenty smooth considering it tops out at over 15mph. I cant imagine using it in a typical scx10 though. How much expo are you using? I think I am at something high like 75%.
03-15-2014, 08:13 PM | #10 |
I'm not sure about the expo on the axial transmitter, I'm thinking my scx is just too light for that much power! This summer il find something to put it in : )
03-15-2014, 08:54 PM | #11 |
Quarry Creeper Join Date: Jan 2009 Location: atlanta
I would say something not right. A buddy we run with has run Pro4 3300kv, T8 esc on 4s and smooth as can be in his SCX10.
03-15-2014, 10:32 PM | #12 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
Im running a 3500kv 4 pole 550 can with a mmp in my scx10. Smooth as silk when I need it to be. Like a elephant In a China shop when I get trigger happy.
Resistance in 4 pole motors - Similar Threads | ||||
4 pole motors. | corkysk8 | Electronics | 1 | 08-13-2011 09:13 PM |
Any HH 5-pole motors users? | Pete from Houston | Electronics | 4 | 12-28-2007 04:23 PM |
5 Pole Brushed Motors! | JohnRobHolmes | Vendors Electronics | 17 | 12-20-2006 10:06 AM |
5 pole motors | chafey | Electronics | 4 | 06-26-2006 09:45 AM |
