03-14-2014, 01:13 PM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| problems with MMP Pro
trying to get my kids rig up and running but i ran into a wierd issue and im stumped on it! ***Not high end stuff here, just to get it running for now!*** Components: LiPo pack MMP Pro ESC (programmed to run brushed/reverse) **Running the motor off RED/BLK wires** Kyosho Mag Mayhem brushed motor TRX Rx 27mhz AM TRX TQ Tx 27mhz AM Problem: When i plug the batery into the ESC, the GREEN LED blinks rapid. The steering is very sluggish. NO response to TH/REV what gives here? self-edit: battery is charged tried 3sets of crystals Last edited by SwampDawg; 03-14-2014 at 01:28 PM. |
03-14-2014, 01:51 PM | #2 |
Rock Crawler Join Date: May 2012 Location: Columbus
| Re: problems with MMP Pro
is the senser turned off
03-14-2014, 01:54 PM | #3 |
okay.....some progress here!! pretty dumb on my part! lol had to calibrate the Tx and ESC but now it still goes back to my servo which could be a bad one? ill swap that soon. |
03-14-2014, 03:06 PM | #4 |
swapped the servo to another but still sluggish. My guess, its just the low end servos that are the problem here. Ill end up just buying my 5yr old atleast a hs645mg for now as they are pretty cheap and deliver some decent Tq. |
03-14-2014, 03:08 PM | #5 | |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
| Re: problems with MMP Pro Quote:
I run one of these with my MMP right now and voltage set to 7v. Boulder moving torque for cheap. Takes a 23t horn. | |
03-14-2014, 03:14 PM | #6 | |
ill have to look into this one but im sure my LHS doesnt carry `Solar`servos. Probably have to check out Ebay? | |
03-14-2014, 03:26 PM | #7 |
| Re: problems with MMP Pro |
03-14-2014, 03:33 PM | #8 | |
http://www.hobbypartz.com/33p-solarservo-d772.html thank you sir Last edited by SwampDawg; 03-14-2014 at 03:37 PM. | |
03-15-2014, 04:22 AM | #9 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
You do have a BEC on it right? If so what's the voltage set to?
03-15-2014, 09:54 AM | #10 |
not on my sons rig i dont. Even if i did, i cant set it higher as it would fry this SF-1. Default voltage is enough for this servo. when i decide to get a better servo then ill consider a BEC. I think the default voltage is around 5v on this MMP. |
03-16-2014, 12:39 AM | #11 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
That stock servo should at least be able to handle 6v. You can turn up the internal BEC a bit from the stock 5 and see if that helps any. It shouldn't do anything to the servo.
03-16-2014, 12:41 AM | #12 |
i did boost it up tp 6v on this SF-1 and it did help a bit but still lacks the speed and power to turn these tires. Also checked all the joints up front... looks as if i need a new servo for his rig. Thanks for the replies! |
problems with MMP Pro - Similar Threads | ||||
MMP / Pro 4 Set Up Question | cmlooner33 | Axial Wraith | 9 | 05-12-2013 11:54 AM |
Mmp pro limited edition | TheKeltz | Electronics | 6 | 05-17-2012 03:50 PM |
MMP problems | ultimate_monkey | Electronics | 10 | 05-14-2010 09:20 PM |
