03-19-2014, 11:57 AM | #1 |
Pebble Pounder Join Date: Sep 2013 Location: Fall River
| Rx8gen2 need a cc bec ????
Quick question ! I'm building ps wraith with rx8gen2 should I put external cc bec or is the internal bec in the rx8gen2 good ? Thx |
03-19-2014, 12:10 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: OC
| Re: Rx8gen2 need a cc bec ????
I am running a RX8 (gen2) on my Wraith with a 7980th, and I did. I let the esc power the rx and lights @ 6v then hooked the cc 10A BEC direct to the servo. Tekin says that they have greatly improved the internal BEC, but I just like to play on the safe side, never gets hot and i run 4s, with a ROC 412 3100kV. |
03-19-2014, 12:20 PM | #3 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
I run mine with 2 servos (1 for steering and the other for dig) hitec 7954, a standard plastic gear servo, a tekin 17.5 gen 1 on zero timing, a gear head light bar and it works perfect. I'll be putting a stronger servo in for the dig soon and I'm gonna see how it goes. And I have the internal bec in my rx8 set at 6v.
03-19-2014, 12:21 PM | #4 |
Did you run it without bec and have heat issues ?? Or never ran without ?
03-19-2014, 12:23 PM | #5 | |
| Re: Rx8gen2 need a cc bec ???? Quote:
03-19-2014, 03:26 PM | #6 |
Pebble Pounder Join Date: Mar 2008 Location: El Dorado Hills, Ca
The Gen2 Rx8 has a 7 amp BEC on both 6v and 8v settings. However if you're running two crazy torque servos and other "accessories" it may be a good idea to split them up on a stand alone BEC, etc.
03-19-2014, 06:41 PM | #7 |
| Re: Rx8gen2 need a cc bec ???? My servo is 277oz at 7.4 and also running VP 5inch light bar but light bar will operate by remote ( and can be dimmed and turned off while running ) so mostly just one servo !
03-20-2014, 12:25 PM | #8 | |
No i never ran the internal on everything, i don't want to overheat the esc, figure out it gets too hot to run all of it, then have the heat damaged RX8. It's nice not to have to check your esc, motor, servo's every few minutes or worry about it when you can do it right from the start. An ESC's primary job is to run the motor, and do it well, the internal BEC's are a gravy item (imo) to the whole thing, as far as i am concerned the most work it should see for a reliable rig is to run the RX, and LED's (max draw 1amp/ constant). BEC's are your friend use them! Hope this helps. | |
03-21-2014, 08:01 AM | #9 |
K thx guys.... I will be putting the bec ! Sent from my iPad using Tapatalk |
03-21-2014, 12:58 PM | #10 |
| Re: Rx8gen2 need a cc bec ???? Yeah mine is the gen 2. I had a cc bec on my gen 1 and it caused glitching, so I don't run one on the gen 2 either. Everything was wired correctly. And there are no heat issues at all. The fan occasionally turns on after hard driving on 3s, but it isn't hot hot, just warm.
Rx8gen2 need a cc bec ???? - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
