Is this a Receiver problem? So i just finished building up my Wraith the way i want it.... Or so in thought. :oops: When i plugged eveything in i had no reverse and my servo was twitching only to the left and when it would twitch it would turn off my ESC and then it would come back on.... What should i do??? My set-up is as follows: ESC: Novak Crusher w/ 17.5T Ballistic Motor Radio System: Spektrum DX3C w/ SR301 Servo: HiTec HS-M7990TH Battery: MaxAmps 3S 5450mah 11.1v True 120c Help would be appreciated. :) |
Re: Is this a Receiver problem? Sounds like you need to complete the ESC bind/setup or your battery is not charged. |
Re: Is this a Receiver problem? i guess i could try charging my batterys just to make sure its not them. Would i need to get a glitch buster and a bec also?? |
Yes a BEC is probably almost necessary with that servo. You could try unplugging it and see if you can get the receiver to power on, then you will know. Speak receivers are sensitive to voltage for sure. That's how I would test it first, then go from there. If receiver works fine, that will tell you that you need a BEC. Good luck |
Re: Is this a Receiver problem? Ok i just fully charged my Batterys and unplugged my servo and it didnt turn off this time lol but i still have no reverse or braking power :cry: |
Re: Is this a Receiver problem? have you tried going over the "one touch setup" for the esc again just incase it hasnt properly learned and stored tx values for throttle channel? |
Re: Is this a Receiver problem? Ive done the one touch set up may times and still nothing........ :x |
I think I'm just going to send out the esc for repair under warranty because I just bought it :P Sent from my DROID RAZR using Tapatalk |
