Thread: Help. Help Will a futaba 3prka work the dig
Old 03-23-2014, 09:36 AM   #1
Default Help. Help Will a futaba 3prka work the dig
The 3 rd channel is just a on off will it work. Help plz.
Tom Collier is offline   Reply With Quote
Old 03-24-2014, 09:59 AM   #2
Default Re: Help. Help Will a futaba 3prka work the dig
Depends on your esc and what your running it in.... For MOA I use a novak m2 dig which is designed to allow dig on 3 channel remotes.... You might need a 3 position switch though.... You might be able to wire a 3 position switch to your remote!
ryanster1999 is offline   Reply With Quote
Old 03-24-2014, 10:05 AM   #3
Yea. I'm running a m2
Old 03-24-2014, 10:14 AM   #4
Lightbulb Re: Help. Help Will a futaba 3prka work the dig
Your best bet is to search the forums and find out how to wire up a 3 position switch.....
Old 03-24-2014, 12:16 PM   #5
If you are in need of a switch type dig controller, I make just what you need:
MOA Dig Controller for Two Position Channel
heyok is offline   Reply With Quote
Old 03-25-2014, 12:40 PM   #6
I'm running a novack m2 dig esc. Do I need that too????
Help. Help Will a futaba 3prka work the dig - Similar Threads
Futaba 3prka radio C00ter Electronics 0 06-10-2012 10:50 AM
Futaba 3PRKA/R203GF input voltage? fastway40 Electronics 2 02-08-2012 03:04 PM
Futaba 3prka God prefers Diesels Electronics 20 07-23-2011 06:05 AM
