03-23-2014, 01:49 PM | #1 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| gt3c hack question
i have installed every thing on my gt3c and can not figure out how to calibrate the throttle or steering. the program or cal screen will not show like it say it will. now i have to set my throttle trim to 99 to get it to stop going backwards is there anything i can do .
03-23-2014, 04:20 PM | #2 |
Quarry Creeper Join Date: May 2010 Location: scotland
| Re: gt3c hack question
ask losikid in his gt3b hack thread
03-23-2014, 05:47 PM | #3 |
There are two things that are happening: 1. After you flash you need to run through radio calibration. This calibrates the firmware so it knows what the readings are from the potentiometers in the throttle and steering. 2. After that, you need to calibrate the ESC to the radio. You'll need to follow the ESC instructions on that depending on what model you have. Radio Calibration Instructions: 1. Wheel right-turn and ENTER-long to enter menu 2. 6 menu items starts to blink (+ 2 arrows if CH3 is set to potentiometer) 3. Use END or ROTATE to change channels 4. There is a channel 4. This represents the battery voltage. 5. To calibrate channel 1 and 2 --Wheel/throttle full left/pull and wait for values to stabilize - press enter --Center wheel/throttle and let values stabilize - press enter --Turn full right/push and wait for values to stabilize - press enter --Press ENTER to finish 6. Calibrated value will disappear from menu after hitting enter for that item 7. You don’t need to calibrate everything, but it’s recommended. 8. Calibrate battery --Select channel 4 --Press ENTER --Set your current battery voltage (measure it by voltmeter) --Press ENTER to save it or END to no-save 9. Press BACK-long or ENTER-long to end calibrate menu and save values Last edited by ik632; 03-23-2014 at 05:51 PM. |
03-23-2014, 06:37 PM | #4 |
thank you very much it is working properly now and my voltage is no longer reading 10.0 v
03-24-2014, 07:57 AM | #5 |
i have one more question how do i program the additional channels
03-27-2014, 07:47 AM | #6 |
Ok so no one knows how to program the 3 channel
03-28-2014, 02:35 PM | #7 |
Quarry Creeper Join Date: Nov 2013 Location: Huntsville
What do you want to do with your 3rd channel? If you want it as a 3-position dig, I can tell you how to do that.
gt3c hack question - Similar Threads | ||||
GT3B Hack Question and Answer Thread | losikid | Electronics | 4922 | 09-23-2023 07:34 AM |
Flysky GT3C: First Look | losikid | Electronics | 104 | 12-22-2013 12:25 PM |
gt3c battery life question | boohoo | Electronics | 5 | 08-06-2013 04:51 PM |
Tamiya 105Bk, Fly-Sky FS-Gt3C Question | Boxcarcustoms | Electronics | 0 | 08-01-2013 12:56 PM |
Flysky GT3B Hack PSX's Custom Firmware 0.61 How to hack? 8 channel 4-wheel steering D | boolean21 | Scale Videos! | 0 | 06-22-2013 12:15 AM |
