03-23-2014, 03:14 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: Burbank
| 13.5T too much for AE2?
So I got a clean AE2 I have run several packs through on 3S with a cheapie 35t motor and today I installed a used HH 13.5t motor that ran great for like 45 seconds on 3s and now it doesn't want to spin the wheels. I can see the light flash red or green, but no juice. Of I spin the tires slowly a little it might go for a few seconds and then stop again. Did I burn up the esc? Is a 13.5t too much for a stock AE2 and I just need to install one of my brxl? Or is the motor worn and needs new brushes or comm turned? Thanks |
03-23-2014, 04:02 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: 13.5T too much for AE2?
Check your brushes out and if you have another motor plug it in and check that way.
03-23-2014, 04:25 PM | #3 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
I thought the ae-2 esc had a limit of 19t... I could be wrong though..
03-23-2014, 04:32 PM | #4 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: 13.5T too much for AE2? http://docs.axialracing.com/instruct..._and_Specs.pdf Specifications: Input Voltage – 6 cell NiCad/NiMH or 2cell lipo** Size – 1.7″ x 1.24″ Weight – 45 Grams Motor Limit – 19t On-Resistance FET – .0018 Rated/Peak Current – 106A Peak Braking Current – 106A Peak BEC Voltage – 5.0V/2A Peak PWM Frequency – 6KHZ |
03-23-2014, 05:08 PM | #5 |
If the limit is 19t, will it really die that fast? Maybe so. I'll try another motor and report what happens |
03-23-2014, 05:32 PM | #6 |
A Holmes 13t Crawlmaster (not a 13.5, that refers to a brushless motor) is a 5 slot armature which is equivalent to a 27t 3 slot armature in resistance. A 13t Holmes motor will not cause the ESC to burn up, it is easier on the ESC than the stock 20t Axial motor is. I have ran hours and hours worth of batteries through an AE2 with a 13t Crawlmaster on 3s. Something else is causing your issue. |
03-23-2014, 07:21 PM | #7 |
| Re: 13.5T too much for AE2? |
03-23-2014, 07:31 PM | #8 |
03-23-2014, 08:44 PM | #9 |
It's the motor. I swapped in. New brxl and it does the same thing: move the motor a little and it goes for a minute then stops. Looking at the brushes they are pretty short, and there is a pretty deep groove on the motor where the brushes rest. Guess the motor is off to holmes for a rebuild.sure wish the guy selling it had told me it was toast, I would have had him send straight to holmes to save one time on shipping.... Oh well. |
13.5T too much for AE2? - Similar Threads | ||||
AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position. | Tread Well | Newbie General | 7 | 06-18-2013 02:14 PM |
ae2 esc ? | chazekxt | Electronics | 13 | 06-24-2012 10:03 PM |
ae2 | RCTRUX | Electronics | 4 | 04-06-2011 05:33 PM |
