Thread: Tekin RS esc and Hotwire
Old 04-01-2014, 03:35 AM   #1
Default Tekin RS esc and Hotwire
Ok I have a tekin RS and while the onboard led programming seemed fine for controllng my HomesHobbies brushed motor, I'm thinking of going brushless and am wondering if I will need the tekin hotwire to dial in a brushless motor or will the onboard led have enough head room to control a brushless motor or should it be enough options? This is in a wraith
realsickclown is offline   Reply With Quote
Old 04-01-2014, 10:39 AM   #2
Default Re: Tekin RS esc and Hotwire
The HotWire is a great tool and can adjust at a higher resolution to really dial in that feel you want. Is your RS a GEN2? If so, you can use the EZ Port adapter and route it to somewhere you can get to, download the HotWire App on an Android device and tune on the trail!
Ty@Tekin is offline   Reply With Quote
Old 04-01-2014, 03:36 PM   #3
No it is a RS GEN1, black case. So it is not compatible with the android app?
Old 04-01-2014, 04:33 PM   #4
Not the current Beta that is up, but there is a new one that will be uploaded soon and it will allow connectivity with the GEN1 ESCs.
Old 04-03-2014, 08:55 AM   #5
When is that supposed to release?
Old 04-03-2014, 11:06 AM   #6
We're expecting a release team wide later this week in which case if no bugs are reported the public will see it shortly after.
Randy P is offline   Reply With Quote
Old 04-04-2014, 03:06 PM   #7
and I'll be able to tune my rig with my android device with this new firmware? I'll still need the actual HOTWIRE unit,correct?
Old 04-04-2014, 03:13 PM   #8
Yes, you will still need a hotwire and the proper adaptor for your device. Google "OTG" cable for your phone/tablet and make sure your device supports that connectivity. Most of the new phones do.
Old 04-12-2014, 07:28 AM   #9
Ty@tekin ,,are there more brake adjustment that can only be accessed via-hotwire? In brushless sensored with a 13.5, the brake won't hold the rig on a small hill. Or am I getting all the brake available thru the led on-board settings
Old 04-12-2014, 08:22 AM   #10
I believe there is a brake setting that produces a more active drag brake. Gearing as low as you can go will help a lot with the drag brake too, as well as start up. I think Im at 97/13 gearing and its pretty nice. Also, play around with the current limiting. I have mine set to 50% and it really smooths out the start up. Happy tuning
sam63 is offline   Reply With Quote
Old 04-13-2014, 12:13 PM   #11
The performance is nice I just don't have much if any drag brake. that is my only complaint with the set up.
Old 04-15-2014, 08:53 AM   #12
Bump
Old 04-15-2014, 09:23 AM   #13
You can maximize drag brake on the ESC without the HotWire, however most of your problem is the motor. 2-pole brushless don't have a very big magnet and will never have as much drag brake as a 4-pole, like the ROC 412 motors.
Old 04-18-2014, 04:08 AM   #14
Well I got the hotwire and it solved all my issues. The motor I'm using is not a 2 pole motor but a 3 pole Viper 13.5. I must confess in stock format the ESC is really throttled back and has a lot of potential with the hotwire. I'm really starting to LOVE this set up. Thanks everybody
