04-02-2014, 02:39 PM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: Roanoke, VA
| Can't change the BEC voltage, new servo..
Hey guys, I messed up and ordered a Savox 1256TG servo, my BEC is set to 7.4V so the servo won't work. I tried changing the setting on the BEC but due to the way I have it wired only two of the wires go back to the BEC and my castlelink will not recognize it. I'm sure the answer is no but is there an easy fix for this aside from sending the servo back or wiring it all over again?
04-02-2014, 02:50 PM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
| Re: Can't change the BEC voltage, new servo..
Do you still have the signal wire (white) coming out of the BEC or did you just de-solder it completely? If so, you can just get a JR connector with pins from places like Pololu and re-install the plug and your Castle Link should be able to recognize it. Worst case scenario is a new BEC and re-program it to 6.0 volts. I don't get why you would need to send your servo back unless you fried it already. My setup is the same in that the BEC powers the servo directly, but the way I did it is just pulled the black and red wires from the connector and I added a male JR connector to directly connect to my BEC while the remaining white signal wire still had the femail JR connector that plugs into my receiver. The BEC then retains all three wires and can be reprogrammed. The only reason I would think you are worried about sending anything back is that you directly spliced the power wires between the BEC and servo together and/or completely pulled the signal wire from the BEC. A picture would help. |
04-04-2014, 09:45 AM | #3 |
I'll have to check when I get home to see how I have the wires ran. Do I need all 3 wires to change the setting on the BEC, or will it work with just the signal wire? I think I cut the BEC's signal wire and siliconed it closed, I still have about 5" of wire though so I could alter it if needed.
04-04-2014, 10:38 AM | #4 |
Just use a jumper for programming, keep in mind also that when the bec is soldered to the power connection that you may need to connect a battery for it to work. The extra connections are sometimes too much for the standard USB voltage to power the bec for programming. Either way it's much easier than sending a servo back.
04-04-2014, 04:39 PM | #5 | |
| Re: Can't change the BEC voltage, new servo.. Quote:
04-04-2014, 05:30 PM | #6 |
I rewired the setup so I could update the BEC. Now I can't' get castle link to recognize it. The link keeps flashing, per the castle link FAQ I need to reinstall the driver. I tried this but Windows claims the best driver is already installed. This is pretty frustrating...
04-04-2014, 05:39 PM | #7 | |
2) Reboot the computer. 3) Reinstall the Castle Link software package. | |
04-04-2014, 09:10 PM | #8 |
04-04-2014, 10:16 PM | #9 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
Is the castle link USB stick flashing red or green? It may flash multi colors but green is there. If just red, you have to isolate the castle link from other voltage besides the computer USB. If green but still not recognizing than there is another issue. Also make sure of the stupid things, such as the wires are hooked up right. Orange to the U symbol, red to + ... Yada yada. I'm in computer repair and it is the stupidly simple things that get you sometimes. Hope this helps not hinders. |
04-04-2014, 10:39 PM | #10 |
I run my 1256 on 7.4 volts so I fail to see the issue.
04-05-2014, 07:39 AM | #11 | |
It shows it's only rated to 6.0v and I read in multiple places that running it at 7.4v will kill it. How long have you been running it like that and can anyone confirm that it's ok long term? | |
04-05-2014, 08:24 AM | #12 |
I run all of my servos overdriven. Minimum voltage to any of them is 7.4 volts from my CC bec. Been running that servo for about a year and a half.
04-05-2014, 10:18 AM | #13 |
The only things that should be plugged in, is the USB cord from computer to link adaptor. Then link to bec. Only bec. No batts. Does castle link software recognize the USB? The software says in the lower left that its found the USB. It has a second box that let's you know its found the ESC. |
04-05-2014, 10:30 PM | #14 | |
" 3. I am plugging into my Castle Link to change the output voltage to my servos, but the CC BEC will not connect. What is wrong? First, verify that you have a green USB connection status in the lower left hand corner of the Castle Link screen. If not, go to the Castle Link FAQ section regarding loading the driver. If it is green but the ‘Device Connection Status’ light stays red, the USB port may not be able to provide enough current to power the CC BEC. Try plugging a battery pack into the CC BEC. This may also be necessary if you’ve already soldered the ESC to the CC BEC. If the problem persists contact Castle Creations Technical Support at support@castlecreations.com or give us a call at (913) 390-6939." A battery is sometimes needed when the bec is already soldered to the power connector along with the esc. For the op: I'd simplify the whole thing. Verify the drivers and that castle link is recognizing the bec and go from there | |
Can't change the BEC voltage, new servo.. - Similar Threads | ||||
What exact thing do I need to change the voltage of my CC BEC? | e32lover | Electronics | 4 | 02-12-2013 10:31 PM |
BEC Voltage | Orph3o | Electronics | 3 | 10-25-2012 10:53 PM |
CC BEC software to change voltage | bullet1231 | Electronics | 7 | 12-20-2008 05:22 AM |
change output voltage? | Georgerm | Electronics | 2 | 07-13-2008 05:49 PM |
How to change output voltage of Castle BEC??? | RedBetta | Electronics | 6 | 12-03-2007 11:10 AM |
